Low engine oil
bowdown916
Sup guys, quick question, i have a 2015 yukon denali xl, and everytime im close to do an oil change it gives me the message that its time,but when i check the engine oil stick i see its either empty or almost nothing. truck dosent leak either,have anyone seem this happen on other trucks?
It is not unusual for an engine to consume some oil during operation or to lose a quart over 7000 miles. If you start changing your oil at 5000 miles or 30% on the DIC, I bet there will be some on the stick.
Get into the habit of checking your fluids regularly, such as every other fuel stop or each Saturday morning or something like that, whatever works for you, to catch these things when they are small problems before they become expensive problems.
B
bowdown916
yea, i will start checking fluids more often, there was one time when i took it to the dealership for oil change and after around half the life of the oil or 50% i got the message to add more,so i looked and i was on empty, not sure if dealership didnt put enough or it was something else,but i when out of town that time and i just had my wife take it to a different place for oil change and after that its just been really low right when its getting close to oil change or around 30%
B
bowdown916
yea i get it,i was just explaning what happen last time :) .. but for sure i will keep my eye on the fluid more often. thank you Ron..
One thing to remember for your engine is that it takes 8 quarts of oil now. The previous generations took 6 and way back in the small block chevy days they took 5. I would not be surprised that quick lube places only put in 6 quarts but would be rather concerned if a GM dealership filled it anything less than 8!
Miami-Dade
Moderator Supporting Member
Sounds like your changing your oil every 7500 miles. I would change it every 5K miles. At 5K miles my oil is just under the full mark and slightly dark amber but can easily see threw the oil stick. AFM is still enabled.
I use only 0w20 AC Delco or 0w20 Mobil 1 and only use AC Delco Filters. Lately preferring AC Delco oil but you can not go wrong with Mobil 1 EP.
All that just IMHO.
avalonandl
Troy, MICH & Naples, FL
You should check it every 2 weeks SERIOUSLY....
CrackerJack135
