Useless Information
Bob2C
Northern VA
looks like prices might go up as it went from 20 to 24 overnight
I told my sister to invest 3 days ago when it was 19$ would have made 2,500$ over night on a 10k investment
It’s temporary. It will drop
My daughter and I installed the Tilt and Shock sensors today to the factory alarm system. GM had never installed these in my truck's configuration so the engineers got involved and updated the software that I would need to get them working.
Little went as planned despite reading the instructions and pouring over the photos for hours and hours. Soon as I squeezed into the foot well many things changed!
First we had to hook up the Tech-2 to the truck and go to the Service Programming section which downloaded the truck's VIN and computer part numbers into the Tech-2 so the ACDelco TDS system could compare them with what is in their library.
Second, take the Tech-2 out of the truck and hook it up to my desktop PC and fire up ACDelco TDS and then the Tech-2. They talk to each other, it is set up for remote programming, then I choose options I want on only ONE module. Made that mistake thinking more than one were being programmed. When that was done, took the Tech-2 back to the truck and programmed the Instrument Panel Cluster module and than repeated the process to program the Body Control Module. This is short version to give y'all an idea, not step by step.
So now that software has been loaded to truck, we can install wiring and sensors. Pull BCM out of its bracket and unplug all the connectors to access three of them. Three wires from the included wiring harness plug into the plugs on the BCM. Then we plugged in the other connector to the Instrument Panel Relay block. Then we plugged in the other sensors and tested them.
Tilted the one sensor and the alarm went off. Banged on the dash and glass and the alarm went off. Adjusted to my liking and then mounted the Tilt Sensor on the BCM bracket but 90 degrees different from instructions to clear a metal bracket. Shock Sensor mounts on wiring harness with zip tie.
Next project where programming is needed will be the 2-Way Advanced Remote Start. Already collecting the individual parts, the complete kit for my truck is no longer available through GM.
Garage needs a cleaning and then I want to do maintenance on the rear brakes and change the transmission fluid. That other post about the stuck caliper reminded me that I had wanted to change my brake fluid last year but ran out of time and energy. Should be able to do it by gravity into cups partially filled with brake fluid. Bought 3 bottles of Lucas DOT3 last year, only one was opened. Have to read the bottle to see if that one is still good.
Hope to get all that done by the end of next week and take her for a nice drive. Control arms shortly after. China Flu keeping the kids at home to help Dad but it sure is costing us a lot of money!
My daughter and I changed the transmission fluid the other day. First we removed the airbox to make it easier to remove the top transmission cooler line from the radiator. We then inserted a Hayden 397 adapter attached to a length of nylon tubing purchased from Home Depot, 1/2" OD and 3/8" ID. Put the airbox back in and ran that line down to a bucket marked at 3 gallons. We started the engine and let the transmission's pump empty the pan, about 6 quarts or halfway to the mark on the bucket.
Then transferred Dexron VI from the 6 gallon box I bought from RockAuto to an old gallon container twice, putting two gallons into the transmission. Then we started the truck again, ran her up and down through the gear selector, holding in each for about 5 seconds. After a few minutes my daughter noticed the color change so the engine was shut off and the Hayden adapter and line removed and the return line plugged back into the radiator.
We then added another 3 quarts and then a final quart checking the fluid at the cold setting even though the transmission's temperature had reached 100 degrees. COLD marks are for 60-90 degrees if memory serves. Took the truck out on the road and then made a full power run through 1st and 2nd to third while merging onto the highway and ran up to the next exit, turned around and came home. Pulled into the driveway with the temperature at 160, checked the level again, it was in the middle of the HOT marks.
While on the run, my daughter monitored the various transmission parameters on the Tech-2 and I later reset the internal Transmission Oil Life Meter to 100% from 77%. Nothing abnormal noticed. As mentioned earlier, we recently sent off a sample to Blackstone-Labs for analysis and the result was that the transmission is in excellent health but the fluid was nearing the end of its service life.
Fluid was changed for the first time back in August of 2017 when the mileage was at 117,432 miles. The fluid had 36,106 miles and 1200 hours on it. We have not been inside yet at any time to change the filter.
Since purchase, one or more of the AC actuators has thrown trouble codes and after three years, all but one had thrown a code at least once! After much research, years, I nailed down which GM and ACDelco part numbers were for each position, or so I thought!
The most troublesome actuator was the driver's temperature control so I bought a GM 89018375 which also had ACDelco's number on the box, 15-72972. This one was made in Mexico by S&G Group.
My youngest daughter took on the task of replacing this one for me and swapped it out. We fired up the truck and Tech-2 and did a calibration, air was blowing hot when it should have been cold, always did the opposite unless manually commanded with the Tech-2. After a couple of relearns, even the passenger side temperature actuator started acting up! She put the old one back in for me and I started googling.
Like we did for the window switches, we came across a company on Ebay claiming to sell the same actuators that shipped with our trucks from the factory in white boxes without the GM stickers, from the same company that made them for GM. I sent them an offer, they accepted, and a few days later the new one showed up. This one was made by CEI, same as the one we pulled out, and is part number 89018365 or 15-72971. THIS is the right actuator for the driver and passenger temperature controls! My little one installed this new one for me, we did the calibration and now none of the others are throwing codes either! All seem happy at the moment!
Knowing that we had so many previous codes, I ordered another at the same price. So this is what I know about actuators; so far:
GMT900 Auto AC
89018374 - 15-73952 = Mode Actuator (Trouble Code B3779) - Driver's Footwell.
89018365 - 15-72971 = Temperature Actuator, Driver's Side (Trouble Code B0413) - Passenger's Footwell.
89018365 - 15-72971 = Temperature Actuator, Passenger Side (Trouble Code B0423) - Behind Glovebox.
Not going to speculate on the others until I see them! LOL
She then did a great job washing the truck, what a kid! Only cost a t-shirt and hoodie from Bass Pro Shops and ice cream; so far!
My AC seems to be fine..... I hope
That one actuator would often not meet the commanded state and the AC would have to work harder to keep the driver's side of the cabin cool. About 18 months ago the clutch started making an intermittent noise at first and then became constant after about a year. Hasn't changed, still chills the air down into the 30s. New clutch kit is about $175 and can be done on the motor.
It was time to reset the air in the tires today. Like to do it when the ambient temperature outside is 75 degrees and began this morning. Wanted to level all the tires off on both the DIC and Tech-2 at 47 PSI. The computers do not like this number and will be even on any number but 47! I gave up and tried again this evening. Same thing, could only get them all to 46 and then a quick spin around the block and they were way off again! Will try again in the morning. She rides so nice when the air in all the tires is within a 1/2 psi of each other.
We also function tested the Tilt and Shock sensors again. My youngest washed the truck the other night and the alarm did not go off. I gave it a quick hit with my hands and was rewarded with the "warn away" signal from the horn and lights. Then my other daughter bumped it enough to move the truck but not shock, nothing happened. I like it like that. Then we jacked up one wheel and before the wheel left the ground the Tilt sensor went full alarm, lights and horn blaring. Awesome. Should have done this years ago.
Now some jerk will get a rude awakening if he thinks he's going to bust out the back window and steal the third row seats without getting caught! 2-Way Advanced Remote Start will complete the trifecta. Also hooked up the dash cam's WIFI to our phones. This way, if we park in high threat area, can leave camera on and see what's going on in and around truck from cell phone and back that up with 2-Way transmitter data.
Chompin' at the bit to get after the parking and rear disc brakes but lots of rain is in the forecast.
All previous trouble codes have cleared out but there's a persistent new one; B2375.
This is the code for the driver's seat horizontal motors circuit. Looks like my fat behind has finally taken its toll on those motors. Printed trouble shooting guide and will put that on the list between rain showers too.
Thunderstorms and light hail over the weekend triggered the "warn away" horn beeps but did not set off the alarm. Did so about 1/2 a dozen times or more. I left the dash cam plugged in and maybe on, came out to the truck today and the battery was dead. Sometime this week I hope to install the 2-Way Advanced Remote Start.
Update:
Put a voltmeter on the battery and it was deader than dead, 8.24 volts. Disconnected it from the truck and put on the 50 AMP battery charger. It's been taking .20 volts every 20 minutes. We're up to 10.07 volts now and the battery case is still cool...
That post was at about 10:00 PM, it's now 11:30 PM and the battery is at 11.09 volts. Still on 50 Amp charge and battery case is still cool. Going to put it on the Battery Minder for the rest of the night and check it again tomorrow. Hopefully it comes back, if not, time for a new battery.
The old school 2A 10A 50A battery charger set at its highest setting last night took the battery to 11.17 volts by 11:45 PM. I then put that one away and hooked up the 1.5A smart charger, the Battery Minder.
The decision to switch was based on measuring the voltage every 20 minutes. The charger was stuffing .01 volts about every minute for several hours and when I noticed it begin to fall off, to about half, that was when I decided to slow it down; and go to bed!
Checked the voltage at about 3:45 AM and it was at 12.45 volts. This morning at 8:00 AM it was at 12.68 volts. So seeing that, I put the negative cable back on and was rewarded with the horn beeping and lights flashing while I wandered around looking for my keys. My lovely wife found them in the kitchen and turned it off for me!
I should probably disconnect the charger and let it rest and see if the charge holds, right? Lots to do today and need the driveway for a few projects I hope to check off the list in this nice cool weather.
Update: Pulled the charger and measured 12.80 volts with Tech-2. Previous readings taken by voltmeter off the battery direct. Letting it rest, after breakfast we'll move it and check the charge again later today.
Took the truck out to pick up my wife from work, was on the road about an hour. We refueled with E85, get this, took on 26 gallons for $36! It was $1.359. Battery Start Up State of Charge was 69% and voltage was 12.8v and battery never really got above a State of Charge of about 71%. I unplugged everything and will check in the morning, if it has significantly discharged, I'll get a new battery for it.
Clock disappeared from Nav unit. Looked up video on youtube while underway and saw a video that takes you into secret menu to reset the date and time. I did that, it came out innaccurate but at least I could then reset it the normal way. Secret code for the menu is 295660.
On another more exciting topic, the Content Theft System has a log inside the BCM. It does not record the horn chirp "Warn Away", only full activation and will tell you what part of the system triggered the alarm. Today it said "Batt. Re-Attached" or something like that. Pretty cool.
Even more exciting, my daughters and I changed the hub on our Pontiac Montana and a tie rod. My youngest spun the inner tie rod and thought nothing of it, the steering wheel is now crooked. But the van doesn't sound like a Harley going down the road anymore and we have to get that toe setting adjusted before it wipes out the new tires. Proud of my kids, they complained like sailors, no swearing, just moaning and groaning, but got the job done and put dinner on the table! I see another trip to Bass Pro Shops in our future.
Now they just dumped a bunch of remotes on my desk to fix...
mountie
BTW - we got a ton of rain here in Naples.
I'm an hour north of you.... I got a 1/2 ton.
I just ordered my Powerstop front - rotors/red calipers & pads..... Also ordered my S.S. brake lines from Russell Performance.
Goodie!!!
BadDaddy2003
