Air bubbles in the coolant reservoir
I'm going to check it all over again, I just ordered a blackstone test kit because I suspect it's a head but it's not showing any signs other than the bubbles, oil level stays the same and looks normal, no problem other than slow coolant loss.
If it's a slow enough leak, the oil will look normal. The liquid will steam off just like normal condensation.
shegarty
I would definitely check the rear heater unit (if equipped) and rule out cavitation on the new water pump and/or residual air in the system. You could very well be dealing with two separate issues.
exp500
It's funny how the sealed systems are so much harder for hoses to seal perfectly. A tiny leak when hot equals a little air in system cold. I think the hoses aren't as good as they used to be.
if it is a head and it's just sucking air into the coolant and not mixing in the oil then I can live with that until a deal comes along for another truck or a engine, preferably another truck. I paid $3k for this 04 about 5 years ago with 100k on it, has 240k on it now, been a good truck if I keep my eyes open I can find another one
Cbncanada
I have the same problem with my 06 yukon xl 1500. Can't find the leak anywhere. Loses about 1 litre a week.
Larryjb
A couple of years ago I had the same issue. I finally had to accept it had to be leaking internally. I put the pressure tester on and left it on overnight. I saw no drips, smelled no coolant inside, the rear heater core was dry.
I finally pulled off the valve cover gaskets and saw this in the thread linked:
https://www.tahoeyukonforum.com/threads/latest-oil-change-oil-filters.99646/page-4
It is important to note that this was NOT a Castech head. To spot this I had to:
  • Remove valve covers, clean suspect areas. Suspect areas are easy to find because leaking coolant partially cleans the area anyway.
  • Install pressure tester and pressurize to 15 psi.
  • Inspect for seepage.
  • Final diagnosis: oil sample analysed and found evidence of coolant.
Removing the valve covers takes about 1/2 hour, maybe less. (I work slowly!)
Also note that if the leak is slow enough, the PCV will remove water from the oil before it becomes milk chocolate. However, over the period of an oil change, coolant additives and ethylene glycol can sludge your oil.
TJ Baker
Colorado
Looking at the photo in that link I noticed the rockers still installed. The TSB on this indicates the castech casting logo can only be seen with the rockers removed. Here's a couple screenshots from the TSB.
I am currently experiencing this very same condition, although I also do not have the bubbles that @Doubeleive has. I have pulled the covers and found a leak/crack...
Larryjb
View attachment 245903 View attachment 245904
That is true. Once I stripped the head of the rockers I was able to confirm there was no Castech logo.
I haven't pulled the covers off yet, it's going to get a oil change in the next couple of weeks and I have the blackstone kit now so I will see what the analysis says before I do anything.
I'd like to see what's going on. My 4.8 with 862 heads on my work van keeps getting low. I need to add coolant about once a month--gets almost empty.
TJ Baker
Colorado
My drivers side cover told the tale as soon as was seen.... Passenger side showed some evidence but I failed to find a leak there.
Larryjb : Expected you would have noted finding any Castech logo somewhere in that thread, posted mainly for the sake of those not knowing where the logo is to be found. I haven't pulled my own rockers (yet) so I can't say whose heads I have other than 706 but I surely do have the leak(s)!!
Still no milk shake in your oil tho? Did other manufacturers make 706 heads other then Castech? Did they make 862's also?
Larryjb
I never had milkshake. Milkshake occurs when oil is emulsified with water. If the leak is slow enough, the PCV removes the water quite well, but not ethylene glycol and additives (inhibitors/buffers). So instead, the glycol and additives cause the engine oil to sludge.
@Tj-baker, at the moment I cannot remember why I figured that I didn't have a Casetch head. It may have been that I didn't realize that there was a bracket covering the location of the Castech symbol, or if I was actually able to peer underneath that bracket. I remember looking for the Castech logo after everything came off and never found it.
Also, the cracked head (which was very obvious in the photos) actually passed the pressure test at the machine shop. The crack was small enough to be a slow leak, and only leaked once torqued down.
Larryjb
Wes, have you put a coolant pressure tester on this? I didn't read any posts where you have done this test. I have found many leaks this way.
it has been tested 3 times, it was loosing pressure previous to the water pump being replaced, after the water pump was replaced it passed a pressure test, then about a month later while getting the oil changed at the dealer quick lube I noticed the coolant was low they topped it off and did a pressure test and it was holding fine, then a few weeks ago I noticed the crossover pipe leaking I replaced that with a new one and it hasn't been tested again since then but the pipe isn't leaking so it's going somewhere.
Larryjb
I'd rent a tester and put it on the test for half an hour or longer to see if you find the leak. Sometimes you have to find it on the ground first before you can look for the source.
For those who have the single crossover coolant pipe on the front, there are two coolant "plugs" on the rear of the engine that would have been used for the spider type crossover. Bottom line is, there are a couple of hidden leak potentials back there.
ya that's one place I haven't checked yet had the transmission flushed and filter changed a couple months ago and the pan is leaking a little or I think it is, really hard to tell the difference between trans fluid and dexcool, i need to send it back to the shop that did the flush and have them do it again so i can rule it in or out.
jkhuntzinger
