Really enjoying this new Denali XL
avalonandl
avalonandl
Troy, MICH & Naples, FL
The Denali is parked in mom's garage and the batterymnder 1510 is hooked up to it. The battyeryminder 1510 brought the battery on my Camaro SS back to 95%.
avalonandl
avalonandl
Put a jackstand under right rear as that tire is losing 5-8 ls per nite. Its either the wheel (this wheel is out of round and chrome is flaking) or have a nail in the tire-
Will deal with it when Corona is mitigated......
Don't need to drive anywhere....
petethepug
Michael
SoCal
Losing about 5 psi overnite on the REAR tires only.
I think its corrosion around the rims. I think the rears are original rims and the fronts were replaced. The chrome looks better on the fronts.
I’d go w/ the corrosion or chrome cladding on the lips of the rims failing. I chased one of my tires for months before I finally had my indie dismount it, use an abrasive wheel to remove the chaff and mount the rim with sealant on the bead.
It’s held pressure for a few months and will get me by until the rims ( or rims) is sent out to be refinished. One of the rims on our Esky is doing the same.
The long term plan is to purchase a Repro or Refurb OEM rim for the Esky and, one by one, get them all repaired. GM’s continued use of a chrome clad process that’s known to fail is greedy and shameful.
St. Louis
One of my 20" wheels has about a dime sized piece of chrome off right at the base of the valve stem. I've noticed recently that this tire will loose about 1psi a day. The other 3 wheels are in great condition.
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
Check CL and FB Marketplace every so often. Someone bought a brand new Denali and stuck those wheels and tires in the shed and forgot about them because they put on 24s or something.
avalonandl
avalonandl
Merch619
