Rear Main Oil Seal
L
Larryjb
Here is a pdf version of my procedure. I have removed the unnecessary steps.
Yes, Mark, I have included removing the axle-diff bolts, but I'm not completely removing the differential. This step takes less than 10 minutes and saves a lot of !@#$%-eh's. If anyone wants to know, I understand that removing the center link/pitman arm bolt allows the center link to rotate away from the differential so that it could be removed completely.
If you see any mistakes, let me know so I can correct them.
Updated to include list of tools needed. Get them ready, job goes faster, more time for beer after.
  • oil pan re and re.pdf
Don’t you have to drain the diff if you pull the axles? I’m not saying any one way is best and don’t mean to beat that subject to death but all I needed to do was pull the bolts that hold the diff to the frame, pry down on it one time and it stayed , and remove the pan. That’s how all the guys I saw on YouTube do it and it worked great. If it doesn’t stay down you can place a wooden wedge in there to hold it down. It doesn’t strain the CV joints any more than if you lifted the suspension, and it’s not being driven while it’s in that position. Just a FYI to anybody doing this. Or do it the other way, it’s up to the person doing the work. I say weigh your options and choose what you think is best. I had no problem cleaning the gasket surface, pulling or replacing the pan. Thanks for your work with that PDF Larry, that’s very considerate of you.
L
Larryjb
I'm not actually pulling axles, rather I'm separating the outer axles from the inner axles. GM actually calls the front differential the "inner axle". There is another set of bolts securing the inner axle to the differential carrier. If you unbolt the inner axle from the differential carrier, yes you would have to drain the differential fluid for sure.
I see. It’s weird that mine came down fine without pulling those. It needed to be pried down but when I did that it seemed to stay. Hopefully I never need to do it again but if I do I’ll keep that in mind.
L
Larryjb
Mine might have come down easily too, but when I saw how much Rickafix had to reef on his I decided it would be easier to just undo 12 more bolts and let it drop.
wildcatgoal
Replaced oil pan gasket without removing diff, disconnecting front differential, disconnecting axles... just unbolt it, lower it, pry it, remove pan, go in reverse. PITA but job done. Get the Mahle gasket -- only one that the main structure is one piece.
L
Larryjb
Nick, sure, it can be done this way.
The only thing I did differently from you is to have separated the outer axles from the inner axles, 12 easy bolts.
"without removing diff, disconnecting front differential, disconnecting axles..." This sounds like a lot of work. I didn't do this:
-I did not remove the differential, just lowered like you did.
-I did not disconnect the front differential, at least not from the inner axles.
-I did disconnect the outer axles from the inner axles.
Yes, it can be done your way, and as you said, it can be a PITA. 10 extra minutes to disconnect the outer axles and the differential drops down out of the way and takes care of the PITA. Actually, because I work slowly, it would probably take anyone else 3 minutes to disconnect the axles. It's that easy to do.
To each his own. I'm just suggesting an extra step that some might prefer.
GMT800 2005 Tahoe Z71
Navy Supporting Member
I think the old phrase that comes to mind is, "Work smart not hard". I personally would disconnect the outer axles in that short amount of time it takes to do it. I have seen attempted short cuts come back and bite a tech in the ass, creating a comeback.
I’m pretty sure he meant the job as a whole is a PIA. This has been beaten to death. Pull those bolts, don’t pull those bolts. It’s not a big deal either way. The job is still a PIA. Not anywhere near as much as the rear main, but it’s a PIA. Anything you have to do under the truck is. I had no problem without pulling the axles apart, I haven’t tried it with doing it and Larry didn’t try it without doing it. Everybody made their point. Time to let it rest. Sheesh.
Sheesh is right. I didn't mean to interject my opinions when you were controlling all abject thoughts on this matter. I bow to your knowledge.
Nevermind. I take this back. Not gonna stoop no more.
No need to be like that, but your opinion is noted. I never said my way is right, didn’t you read? I said to make your own decision. Your sarcasm is also noted once again.
L
Larryjb
Got things back together. Unfortunately, the leak is still there after doing the oil pan gasket. But, there is oil dripping from the back of the engine, off one of the starter motor mounting bolts.
I suspected the rear main seal, so I guess I have to do it now. The only problem I have is that GM Autotrac II is rediculously expensive here in Canada. I'll probably drop the transfer case without draining it. I'm not sure about transmission fluid. That might be a similar problem too.
JonnyTahoe
Minneapolis
Fel-Pro also is good. For 50 bucks it better be.
JonnyTahoe
Minneapolis
Don't feel bad Larry I spent hours just getting prepared and jacking my Tahoe up with such over-kill in the safety department because I just hate being under these trucks. I had so many extra floor jacks and 4X4's in various places under the truck it actually made it harder than it should of been because all my jacks were in my way during the Multi-night job.
L
Larryjb
Thanks John, I don't feel bad. I figured it was the rear main, but I knew the oil pan had to be done so I took a chance. The only "extra" work that has to repeated to do the rear main will be to remove the front drive shaft and cross member. That will take me 10 or 15 minutes. The real pain is getting fluids. Stuff is SO expensive here in Canada.
Funny you mention jack stands. I don't feel comfortable unless I've got my Tahoe sitting on 6 T jackstands. I don't think the job will be too bad, just a lot to take off. I've got most of the parts already. Either ACDelco or Felpro gaskets, I've got a nice low profile transmission jack.
JonnyTahoe
Minneapolis
You should drain the case if you have never done it before. You do not have to use Autotrac. My trans had a internal seal failure and it filled my T-case full of auto store trans fluid I never noticed any problems till the trans itself failed.
L
Larryjb
I'll drain the transfer case as soon as the border reopens. I can get Autotrac II cheap from Amazon.com, and pick it up easily from across the border. Besides, I should probably do that plate that protects the case. Again, getting parts into Canada is not so easy right now.
JonnyTahoe
Minneapolis
Sucks your Fluids are so expensive. Hey how about that ''Rickafix video''. Are you kidding me. I had a hard time just watching it. The truck was 2 inches from his face. Got to give the guy Credit for taking the time to make a video of that nightmare job and remember that was his Second time doing it because he Did a fast job the first time and cut a few corners because it sucks working under a five thousand pound truck and he also still had a leak and ended up doing it all over a second time.
JonnyTahoe
Minneapolis
Never been to Canadian boarder and I'm less than 500 mi. from it.
JonnyTahoe
Minneapolis
If I were to do the Oil Pan Gasket again as much as I don't like removing Steering Parts, I would remove that Steering Link in a second. That Link made everything take so much longer. Working on your back upside down sucks. My Yukon I got last September is absolutely rust free from Richardson Texas. It's a RWD 4X2. Try finding one of those in the upper Midwest. I can't even wait to replace the Oil Pump Tube O-ring and the Pan gasket should almost be kinda fun no front Differential.
Buford bubba
