Adding Garage Door opener
Hogfan
I recently purchased a 2013 Yukon SLE and want to add the stock garage door opener(homelink). I have found a few roof consoles for other trim packages on Ebay with the garage door opener. I have not been able to find one with just the garage door opener. They have control buttons for the sunroof and/or power folding seats (which I have neither) Will this work? Has any one changed this out?
Big Mama
Virginia
Sorry I can’t help with this one but welcome from Virginia. Others will chime in soon.
Check out 22750009. Plug your VIN in at GMPartsDirect, go to BODY and OVERHEAD CONSOLE and have a look. The PN# I gave you is for a 2009, which may be slightly different but would fit.
Welcome to the Forum from NH.
Unfortunately, I cannot help you with this specific question.
You've already seen one recommendation, and others will chime in with their suggestions.
Danny3737
Unless you park in your garage, the last thing you want to do is set up a HomeLink, because if somebody breaks in to your car they will have easy access to open your garage and help themselves to whatever they want. I took one of my openers apart and added a small momentary switch I got from HD for less than $3.00 and hid it in my truck. I did the same with my wife’s and all 3 of my kids cars. If you can solder, it will only take a few minutes to do each one. It will take you longer to figure out where to drill the hole and mount the button. I placed mine up high so I would have a longer range.
I don't understand what your momentary switch does. Are you modifying the opener controls or the HomeLink? Could you describe this in more detail for a cretin like myself?
Danny3737
Your regular garage door remote and HomeLink buttons are momentary buttons as opposed to the regular on-off type. All I did was tap in an external momentary switch. I installed mine on the backside of the overhead console where nobody would think to look.
It allows me to put the
Danny3737
It’s similar to this. Just use your imagination on where you want to locate the button
Still kinda foggy. It looks like the theory is to bypass the HomeLink button and hide the momentary switch? If you're not bypassing the HomeLink button then how is this secure?
Or is the theory to have two momentary buttons in series so that they both need to be pushed at the same time?
Separately, it seems like wiring an opener remote with a fixed switch would defeat the wireless portability of the remote.
Danny3737
I have the HomeLink in mine, but don’t use it, since I don’t always park in the garage and if somebody breaks in to my truck they will be able to open my garage with the HomeLink. I also don’t want somebody rummaging through my truck and stumbling across my remote. Using a remote momentary switch just gives me more flexibility on where to hide the button. I have a few thousand dollars worth of tools in my garage and I don’t want some scumbag going on a shopping spree.
I reckon you leave the truck at home often? I don't leave the house without my truck, don't drive in anything else, tis the law! LOL
Danny3737
That’s correct. I only drive it on the weekends since I have a company car. Most times it’s in the garage, but now I’m getting ready to move and my garage is a little full right now.
foeteef
They do have a few on ebay, you didn't specify what color you have,but as an example are you referring to this type?
qcon
Huntsville, AL
Why GM decided to make the button hot all the time is a mystery. It’s as if the engineers never thought about security. I was worried about a thief getting access to my garage overnight, so I plug my garage door opener into a smart outlet that turns off overnight.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
This gives me an idea. You could interrupt the button with a relay triggered when the ignition is on.
kbuskill
NE. FL.
Or you could find the pin out diagram for the connector the homelink plugs into and just disconnect the 12+ constant and use the 12+ ignition lead instead... found in the mirror harness right there by the homelink.
kbuskill
NE. FL.
Here you go... this should help you get started...
Now all you need to do is find a diagram for the homelink buttons harness and your set.
The only issue I could forsee with this is if the 12v + constant wire also provides power for the other things in that console, like the powered lift gate, 2nd row power folding seats, etc.... you just wouldn't be able to use those features without the key on.
George B
¯\_(ツ)_/¯
I am not doing the mod but perhaps the OP will be. I think this is great info tho. I think one could make the wiring changes without loosing the function of the other items tho.
RST Dana
OH
I’m guessing I can reset my garage opener, in the event my ride is no longer in my possession. I have the ability to see the status of my opener on an app as well.
Buford bubba
