2008 Yukon Denali, 135k miles, part 2!!
How have I missed this thread?!
Also I found the 15mm bolts into the bell housing don't match. I wonder if my trans gas been out in the past.
My bottom two bolts were like that and I thought the same. I've owned mine since 147K miles, and the oil pan has been off prior to my ownership, so I just assumed they lost one of the correct bolts and threw in a different one.
T
tgui
Pan prepped with gasket, rivets, and new oil cooler cover and gasket.
Surface prepped.
But wait! The dipstick was touching the header. F*CK. So I bent it. Then the brace/bracket broke.
So I bent it another direction. It doesn't touch but the zip tie holding it in place bothers me.
Soooo I got a fancy dipstick on order made by Lokar.
T
tgui
I've seen a TON of thos ps coolers leak from corrosion. I am in Jersey tho--salty, snowy state. I deleted mine because of that.
I understand. I live in the DC area, did undergrad in CO, and grew up in AK.
Rust is life.
BUT, please tell how you deleted all that? Like you have no power steering?
BadDaddy2003
