Always get the service suspension message in my display
DJPoertsch
Germany
Hello dear friends here from the forum.
I need your advice and tips on how to solve my problem.
I'm driving a 2007 Tahoe LTZ with an Air Ride System here in Germany. This system was already replaced by the previous owner and changed to normal shock absorbers. The resistors were also electrically connected to each shock absorber and I replaced them with new resistors.
The reason was that since I bought the car, this service suspension light has always been on and I have to delete the error message by pressing on the instrument cluster.
I myself an electrician and know how to properly install resistors. I installed and connected these resistors to all 4 shock absorbers.
What can be the problem why this message still lights up?
Do I still need the compressor at the back or can I remove it? It looks pretty old and doesn't seem to work anymore. Because I don't have Air Rider shock absorbers anymore? Or I'm getting more trouble Codes if I uninstall the Compressor.
I would be very happy about your tips because the report message is very annoying. Thanks to all.
Is the ABS light on as well?
If not, it's probably related to the compressor. You can't just unplug and remove it since the system needs to see the valves operate with the system self-check. Have you pulled the fuses for the compressor? I think the proper procedure is to disconnect the battery, then remove the associated fuses, then reconnect the battery. Looks for the fuses labeled "ALC" and "ALC EXH". I think that's what they're labeled as.
Since the shocks were replaced, check the harness connections on top of the frame rails next to the upper shock bolts. They are very easily knocked loose when you're working in that area with a ratchet or especially an impact gun to remove the upper shock bolts. One of these being disconnected would also cause an ABS light, though.
DJPoertsch
DJPoertsch
Germany
Thank you @iamdub
The ABS light does not light up. I only get the message every time I start the Tahoe. Then I delete it and drive off.
I will test it by removing the fuse. Because I don't know what else I can do.
What I also noticed is that when I drive from my home mountain down with my Tahoe I always get this Stability Track message for 3-4 seconds. I already thought that it was related to the ABS But I usually get it when it's raining or cool outside. And only when I go downhill. If I drive uphill I've never had the mistake.
But thanks a lot @iamdub for the tip with the fuse. Should I leave them out completely?
Greetings from Germany
You can leave them out since the system is no longer in use.
StabiliTrak warning message could be from a number of things. Your best bet is to have a TechII or other scanner capable of reading the suspension codes direct you to the fault. It could also help with your suspension system warning issue.
DJPoertsch
DJPoertsch
Germany
I have a TECH II on my laptop. But I have to find my way around because there are many options that can be used.
I know how I find my Tahoe in TECH II but I haven't found any direct code to point out this Stability Track error. Because it comes and goes by itself.
I will test the fuse immediately after work tomorrow. Because I haven't looked it up since I bought this Tahoe.
Do you know in which fuse box I have to look for the Fuse. Inside next to the driver door or under the hood ?
Under the hood.
DJPoertsch
DJPoertsch
Germany
@iamdub
I was replacing all your Fuses as you say. But my message still come on after I start the Ignition key. This Fuse Thing would not solve my problem. Sorry
@iamdub
You have to remove them and leave them out. This will disable the ALC. Your message is probably for the AutoRide system, though. What does the message(s) say? Service Traction Control? Service StabiliTrak? Both?
DJPoertsch
DJPoertsch
Germany
I was take them out and store it on the parking place of my fuse cover inside the driver door. They not more active. I think it was port 54 and something 58 and 2 of the diagram in the fuse Box under the hood.
Sorry @iamdub it was my mistake .. i was taking them complete out.
DenaliReyes
Detroit, MI
Did you get it fixed, my 05 denali xl says service stability control. I put resistors in them wires. Has. On auto ride shocks.
I havent messed with the compressor.
DJPoertsch
DJPoertsch
Germany
Hello everybody. I would like to give you a little update regarding my error with the Stability Track Control error message.
I installed an LPG system in my Tahoe because of the fuel costs in Germany.
We have now checked the system and the error was due to the fact that the engine was set too lean when the engine was run on LPG and after accelerating to the partial load range the LPG air mixture was set too lean. The second problem was that I had installed cheap oxygen sensors in 2019 that were defective. I have now installed originals and readjusted the LPG system on a test bench. I haven't had this error since then.
So only my Suspension service message would come on every time I will start my Tahoe. I try to figure out what else it could be. Fuse all out and still the message come on.
Jumpshot12
