ivin74
05 NBS Nali
New:
- Pitman arm
- Idler arm
- Idler bracket
- Upper control arms
- Lower control arms
- Camber adjustment plates
- Camber adjustment guide pins (get the Moog ones, not Specialty Motor Products)
- Front and rear bump stops
- Inner and outer tie rods
- Driver's side wheel bearing/hub
- Front differential axle seals and bearings
- Replaced broken front axle shaft tube
- Fluids in everything but transmission
- Oil pan gasket and O-ring
- Spark plugs
- Spark plug wires
- Steering column bearing
- Steering upper intermediate shaft
- Shift lever boot
- Cabin air filter
- Pioneer 2DIN stereo
- Image Dynamics speakers
- Backup camera
- New key fobs
- Energy suspension torsion bar mounts
- Replaced roof antenna that was missing
- Upgraded alt to battery wire to fused 4AWG
- Replaced idler pulley bearing
- Adjusted parking brake
- Front rear brake pads
- Front rear brake hoses
- Variable power steering bypass
- Power steering fluid
- Added power steering filter
- Rebuilt steering box
- PCV
- Fuel filter (FFV)
- Rear pinion seal
- Serp belts
- Amplifier bypass harness
- Bilstein shocks (front)
Took me couple hours............
A couple of hours to replace all the items on your list? How many people were on it?
