TheAutumnWind
New:
- Pitman arm
- Idler arm
- Idler bracket
- Upper control arms
- Lower control arms
- Camber adjustment plates
- Camber adjustment guide pins (get the Moog ones, not Specialty Motor Products)
- Front and rear bump stops
- Inner and outer tie rods
- Driver's side wheel bearing/hub
- Front differential axle seals and bearings
- Replaced broken front axle shaft tube
- Fluids in everything but transmission
- Oil pan gasket and O-ring
- Spark plugs
- Spark plug wires
- Steering column bearing
- Steering upper intermediate shaft
- Shift lever boot
- Cabin air filter
- Pioneer 2DIN stereo
- Image Dynamics speakers
- Backup camera
- New key fobs
- Energy suspension torsion bar mounts
- Replaced roof antenna that was missing
- Upgraded alt to battery wire to fused 4AWG
- Replaced idler pulley bearing
- Adjusted parking brake
- Front rear brake pads
- Front rear brake hoses
- Variable power steering bypass
- Power steering fluid
- Added power steering filter
- Rebuilt steering box
- PCV
- Fuel filter (FFV)
- Rear pinion seal
- Serp belts
- Amplifier bypass harness
- Bilstein shocks (front)
Took me couple hours............
JFC I could take a couple hours on like one of those items... should probably spend less time sippin beers while I'm working I guess.
TheAutumnWind
The folks at GM gauge repair replaced the overlay, I think that's what makes the display look like that.
In order to run the white LED you need to replace the overlay, the oem overlay has a blue tint over the gauges. Look at the picture below
https://www.gmgaugerepair.com/?gcli...XAXF6mm7cw8_PcJbECtoRXgIX6qvJ7_hoCNjEQAvD_BwE
Boy, oh, boy..... That website is a candy store!! Nice prices...
No kidding. Damn I really need to get off my ass and get my gauges fixed. Super dim...
I recall this being brought up a short while back. Do they have a general/blank affidavit that we sign or does it have to be more official than that, like getting it notarized?
Blackbear just now emailed me a document via DocuSign that I was able to fill out and sign online. It states the truck will never be driven on the road and that I take full responsibility if I get busted by the EPA for removing a smog control device. It just covers their ass. It’s not like the smog police are going to come snooping around my place. Cats be damned!
Nice! Glad it's something easy. I fully understand and agree to why they do that. Really, I'm most apprehensive about how to e-sign such a document. I bet this and the other computer-related aspects are gonna be my biggest hurdles in getting a tune.
golavaman
