Kee Fuller
las vegas
My Tech-2 does not have enough "power" to stay on when the engine is started, it resets. This could be avoided with external power (plugged at the Candi Module for GMT900) and maybe from the cigar lighters. 99% of the time it gets power from the OBDII port.
My cigarette lighter doesnt produce enough power to turn mines on.
R3cord303
Posse In Effect
Oregon Valley
Sometimes with the powerfold mirrors, when they shake at speed, you need to push them out, then bring them back til they click. Kind of locks them back into place. Works with the nbs mirrors.
when my grandad owned it he ran the mirror into a fence real hard. He flopped it back but power fold doesn’t work and it wobbles a bit
HiHoeSilver
Away!
Chicago
The drain plugs are under the plastic/rubber flap along the bottom and are oval. Remove them from all the doors and throw them as far as you can into the closet pond.
The rear corners of the door seam weld should have a drain hole, but they're small and easily get clogged. You can take a zip tie, unfolded paper clip, or toothpick and unclog those too, but with plugs removed you'll be good.
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
Fyp.
Ha, my rear passenger door likes to fill up with water. I popped one of the plastic rivets halfway out the last time it filled up and about 3/4 a gallon came out. I just left the rivet halfway out and that seems to have fixed my problem
Plastic rivet? Can you get a pic of one?
St. Louis
Think he's talking about the round christmas tree type fasteners that hold that bottom weather strip/flap on.
Fhe oval drain plugs are lower than those and under the flap
2001 Yukon SLT
Kee Fuller
las vegas
2001 Yukon SLT
Thats what originally thought. Mine are prolly clogged. I'll check when i get home next week
