The plugs are the rivets that hold the seal in place? Pop em out so they are sitting flush?
Open your back door, get on your knees and look under the lower door edge, you'll see a plastic plug type thing that's just pushed up into place. Just pull it out--that's the plug that'll let all the water that's trapped in there, out. It just pulls out. Should be a rubber plug.
Well that was fun, had to take the gear apart twice because it was jammed up or something, had to improvise to get the spring off with some sleeves because my vice isn't big enough but got it done, works slow and wimpy but better than nothing at all, old gear was cracked
St. Louis
The drain plugs are under the plastic/rubber flap along the bottom and are oval. Remove them from all the doors and put them in a zip lock and place in a drawer in the garage.
The rear corners of the door seam weld should have a drain hole, but they're small and easily get clogged. You can take a zip tie, unfolded paper clip, or toothpick and unclog those too, but with plugs removed you'll be good.
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
St. Louis
Must be a woman thing... my wife does the whole hand wrapping thing too, drives me nuts... lol
I take a measured amount and fold it neatly in half and then in half again before using it... very neat and orderly and symmetrical.
No need to fold and/or fold again if you use good paper. I only do that when somewhere that has thin cheap 1ply paper. At home we use Charmin Ultra strong Mega rolls
2001 Yukon SLT
kbuskill
NE. FL.
2001 Yukon SLT
Yuck... I can't stand Charmin... feel like I'm wiping with felt... very linty, is that a word... I don't think so but I just used it.
I'm an Angel Soft kinda guy.
St. Louis
The ultra strong (red package) isn't linty like the ultra soft (blue package). It works well with hairy butts... Lol
2001 Yukon SLT
2001 Yukon SLT
2001 Yukon SLT
Quilted Northern gets two thumbs up in our abode.
:confused::eek::eek:
ONE WORD GUYS--DINGLEBERRIES lol!!
kbuskill
NE. FL.
2001 Yukon SLT
I was unaware there was an ultra strong... guess the ultra soft is the only one I have experience with... good to know.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Flushable Wet wipes work the best
They are great for getting clean but raise all sorts of hell in the treatment plants.... I spent some time brainstorming with a customer how to keep them from getting balled up on a chain that drives the paddles in a tank. They would cause the chain to come off the sprocket and fall down into the tank.
Phlipnstik
