Well that was fun, had to take the gear apart twice because it was jammed up or something, had to improvise to get the spring off with some sleeves because my vice isn't big enough but got it done, works slow and wimpy but better than nothing at all, old gear was cracked
View attachment 243372 View attachment 243373 View attachment 243374
My gear was in three pieces. It's a little slower than the driver's side now and much louder but works. Every man needs a big vise! I've got a Pre 1940 Columbia, a four inch and 3.5 inch Craftsmans from the 1980s and a couple of hobby grade ones for modelling. Also have parts for a wood vise for my next work bench.
As for the other popular discussion going on, we're a Cottonelle family here with a big shout out to Dude Wipes! LOL
BG1988
I have 4 kids in the house and they get stupid with TP but we don't go thru 4 rolls a day, lol
thinking about doing the mirror gear today since the weather is nice
1 roll last about 1 week for me unless i have a running nose but i do use those to prevent splash back if was going to take a poop or piss
it's called recycling
stocked up as well way way before the virus thing
back when we had that 6.4 and 7.1 in ridgecrest
got at lest 13 cases of water and lots of wipes and TP 100+ rolls
(as if there is an Eathquake we will have no water for a while. 3-6 months or so)...
13 cases is only good for the first or two week or so though between 7 people, it's in regular rotation so it can get down to 6 cases or so minimum
sooner or later the San Andreas is going to rip open
the last time the most southern section ripped open was 1680.. so it has plenty of build up to be released
more then likely the will produce a MegaQuake as the whole entire fault will rip open from San Diego to San Francisco
ya if the andreas fault goes all power lines that crossover it into so. cal would break and it would take them months to fix, I live on the east side of the calaveras fault which is part of the far northern end of the andreas it's about 20 minutes away so where I am at we would likely be fine, if it goes you would probably see a lot of people leaving california for a while which would be a good thing ;)
BG1988
honestly i'm very tempted to go on a trip right now as the price is cheap enough to drive 2k miles it would only cost me 200-220$ for gas
mikeyss
Longmont, Colorado.
Get ya a harbor frieght case. Also double check to see if ya power car adapter works. Mine powers up, but doesn't produce enough power to turn the tech 2 on. Its not a big deal, i use the the battery clip one
I tested mine out and the OBD port does power up the tech2. I didn't have a lot of time to mess with it yet, but I tried a few things out. I increased the alternator output and watched the volt gauge climb, commanded the lights on, watched the O2 sensors which I think may be lazy, and commanded the cooling fans to run. It's damp and cold today, I'll mess with it more tomorrow
The only time you would need the car 12 v adapter would be to program modules in which case I would suggest using the 120v adapter anyway. Otherwise like you discovered you can just power it through the obd port.
Working on Wilwoods for The Machine today.
My Tech-2 does not have enough "power" to stay on when the engine is started, it resets. This could be avoided with external power (plugged at the Candi Module for GMT900) and maybe from the cigar lighters. 99% of the time it gets power from the OBDII port.
St. Louis
Drove it the ~550 miles home from eastern Tennessee with the family and luggage/gear. Cruise set at 80 most of the way, sometimes would go a bit faster, 85-90 for a bit. Average mpg got up to 17 for a bit but pretty much stayed on 16.8. Engine rpms were about 2k, maybe a couple hundred more.
I love that even with it loaded down as it was and at those speeds it has gobs of power. Going up and over mountains it would downshift, but the rpms stayed under 3k and I was able to pass everyone.. Lol
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
Kee Fuller
las vegas
My cigarette lighter doesnt produce enough power to turn mines on.
R3cord303
Posse In Effect
Oregon Valley
Sometimes with the powerfold mirrors, when they shake at speed, you need to push them out, then bring them back til they click. Kind of locks them back into place. Works with the nbs mirrors.
when my grandad owned it he ran the mirror into a fence real hard. He flopped it back but power fold doesn’t work and it wobbles a bit
HiHoeSilver
Away!
Chicago
The drain plugs are under the plastic/rubber flap along the bottom and are oval. Remove them from all the doors and throw them as far as you can into the closet pond.
The rear corners of the door seam weld should have a drain hole, but they're small and easily get clogged. You can take a zip tie, unfolded paper clip, or toothpick and unclog those too, but with plugs removed you'll be good.
2001 Yukon SLT
Fyp.
Ha, my rear passenger door likes to fill up with water. I popped one of the plastic rivets halfway out the last time it filled up and about 3/4 a gallon came out. I just left the rivet halfway out and that seems to have fixed my problem
Plastic rivet? Can you get a pic of one?
St. Louis
Think he's talking about the round christmas tree type fasteners that hold that bottom weather strip/flap on.
Fhe oval drain plugs are lower than those and under the flap
2001 Yukon SLT
Kee Fuller
las vegas
2001 Yukon SLT
Thats what originally thought. Mine are prolly clogged. I'll check when i get home next week
Phlipnstik
