Magnaride rear strut replacement questions
06 Taco
We recently bought a 2015 Denali with 36500 miles on it and the Z95 magnetic ride control suspension package. The drivers rear strut is leaking and I want to replace both left and right rear at the same time. I'm considering the Arnott AS3066 struts as a replacement. Has anyone installed Arnotts on there trucks? what is your experience? Are there other options other than AC Delco GM replacements?
I'm not ready to delete the mag ride at this point in time but I don't really want to replace the struts with OEM units that don't seem to hold up. Thanks for any input from the forum
Big Mama
Virginia
Arnott seems to be the go to if not using GM parts. 35k is awful fast for shocks to wear out. Is anything rubbing? Does the compressor run longer than 10-15 seconds at start up? Maybe the PO overloaded it by a lot?
06 Taco
06 Taco
Thanks for the reply Big Mama
I haven't heard or seen any indication of rubbing to date. I will check the compressor. Can you tell me where it's located? Every thing on this vehicle is new to me. It's a far cry from my 06 Z71 Tahoe.
The PO may very well have over loaded this vehicle, my impression is that the truck wasn't all ways used as a grocery getter, it was used as more of a truck which is basically what it is. I bought it from a dealer so I never met the previous owner and didn't get any info on how it was used.
Big Mama
Virginia
I have an 07 but I think it’s still behind the driver side rear tire. The rear shocks are just air not magnetic (at least mine are) for auto leveling. If they or a line had a leak you’d hear it running quite a bit but since you see fluid it’s time to change them. Arnott is a good choice.
06 Taco
06 Taco
Nice Link, Thanks Trides.
I can see where the confusion comes from. The Magnaride and air struts and shocks look identical at first glance.
cireallin
These should be under warranty if they are leaking?
06 Taco
06 Taco
I assumed that I was out of warranty on suspension components after three years or 36000 miles. Is the suspension covered under a different part of the warranty?
JasonW4141
