Fake spring here, NorCal likes to tease us and then go back to being cold again
Tonight might be the night, I need to pay attention to catch it hitting 320.
And 3 days since the evap valve replacement and no engine light so far. :)
Impressive and inspiring.
As of today's trip, I'm now less than 100 miles (96?) from 200K, and from pulling the motor.
Sam Harris
You’re pulling the motor at 200k? You going to rebuild it, or replace with a built 6.2? [emoji16]
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
If we got 3 full months each of the fall and spring “in between”weather like we used to I wouldn’t complain. Seems like it goes right from one extreme to the other anymore. Remember beautiful skies 55/75 temps for more than a couple weeks? Miss that shit.
Me too! Spring is the worst. March-May sucks around here.
Bigkevschopshop
Northside H-Town
Show off, with your *79 degrees crap... :p
Sick of this cold, ****** weather up here!!! :Angry:
When its 100 for 30 days straight this summer, Schweatty nuts and all, I will be wishing I lived where it got cold... I can put on more clothes and go in public in cold with no issues, there is a limit for the general public on what I probably should not take off in hot weather........
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Ahhh but the ladies son!!! They seem to have less limits every summer to what they wear!! :)
alexalex
[/QUOTE]
Wixey makes some neat digital angle finders that are pretty inexpensive. I use them in a lot of applications both at home and at work when setting up equipment.
Fully agree! I personally have a Wixey angle finder reviewed by ProductAdvisor that I am finally beginning to use, mostly to help me find new or forgotten locations of objects. It is a great tool for first time finding. If your angle finder is not self zeroing, be sure to do that, and then you are set. The Wixey is very compact and works well. It's drawback is the brightish green display on the model I have.
I wish I was ready to replace it with a 6.0 or 6.2! It doesn't need a rebuild. Just gonna delete the AFM (already disabled in tune), refresh and re-seal it. Has a small oil pan gasket leak but since it'll be out, it'll get all new gaskets along with the lifters, oil pump, timing set, rockers, valve springs, etc. Really, the only thing I'm leaving alone is the rotating/reciprocating assembly and all the bolts except for the TTY ones.
Sam Harris
I wish I was ready to replace it with a 6.0 or 6.2! It doesn't need a rebuild. Just gonna delete the AFM (already disabled in tune), refresh and re-seal it. Has a small oil pan gasket leak but since it'll be out, it'll get all new along with the lifters, oil pump, timing set, rockers, valve springs, etc. Really, the only thing I'm leaving alone is the rotating/reciprocating assembly and all the bolts except for the TTY ones.
Niiiice.
Phlipnstik
