how long does your steering sensor last?
fyremanpat
Fyremanpat
I seem to be replacing mine every year or so. does anyone else have this problem?.. and Im using Napa sensors.
ridehuff
bismarck ND
what happens when it goes out? sometimes my hoe jerks to the left when im driving straight. i replaced my balljoints and arms.
fyremanpat
fyremanpat
Fyremanpat
GM designed it so that at slow speed and rpm it makes the steering very light, and then at speed it tightens back up..when the sensor go's bad it wears spots in it where it cant determine the speed thus loosening the steering at speed...which is very dangerous. If your steering is doing that, replace it. Its a HUGE difference.
puckhead
CO
No trouble with mine for the 100K+ miles. Mine is a NBS though, I dont know if they made any changes to it
fyremanpat
fyremanpat
Fyremanpat
i didnt think the newer ones came with a steering sensor..
puckhead
CO
You could be right, I just know mine has something that makes the steering looser at low speeds and tighter at high speeds. I assumed thats what they have but you know what assuming does lol
Grebbler
Parts is parts...
Michigan
That's supposed to be a symptom of an erratic steering sensor / EVO system.
You can reach under the dash for a wire harness connected near the bottom of the column and disconnect it and see if the jerk goes away. The steering controller should stay in EZ mode when disconnected.
magnahoe
MA
No problems with that since Ive owned my hoe. when I got it the steering was all jacked up did ball joints and arms. My steering is still a little lose and I have a power steering leak but it drives perfectly straight.
TheBeast99
hmmm, i wonder if i should get mine checked then.
at the same time, my steering feels just like my dad's 96 S-10 Blazer did back in 2005, both in the city and highway, so i'm guessing there's nothing wrong with mine either.
ChiefTW
