Brake bleeding
rockola1971
Indiana (formerly IL)
You guys are doing it wrong. Tech 2 scanner...One man bleeding and let the ABS pump do the work for you using the brake bleed function in the tech 2! Its fast and works great.
the guy working the bleeder valve is the boss... hes yelling, PUMP. HOLD EM. PUMP, HOLD EM. TILL HE GETS FLUID ONLY LOL
My pump method also incorporates cycling the key at specific times with the pedal stroke, and I ain't about to try to explain this to a helper when I can do it all by myself in a fraction of the time.
I crack the bleeder, slip on the clear tubing, work the pedal and key while watching the fluid in the tubing with my GoPro sync'ed to my phone, check the reservoir, etc. I can replace the fluid in the entire system and bleed it in about 30 minutes by myself.
Hrocks
Hey guys, I'm going to replace my rear brake calipers. My left rear is grabbing bad. I'm also replacing the rubber brake lines on both sides. When bleeding the brakes I assume you go about it one side at a time? Or do you bleed them at the same time?
Sent from my SM-N920T using Tapatalk
Livebai8
Livebai8
Houston, Texas
I have an opportunity to use a pneumatic brake bleeder once I get to this point. Who's used one? How did it fair? Was easier than is it manual bleeder? Also...should I empty the fluid reservoir and fill will with new fluid before bleeding? I'm changing the rear rubber hoses tonthe calipers too.
Scottydoggs
NJ
i use a turkey baster to suck out the old fluid, then fill it up with new fluid.
never used that type of bleeder, but they will will do the job as well.
Livebai8
Livebai8
Houston, Texas
Do you empty the reservoir completely or leave just a bit and fill with new and refill as needed until all bled?
Your will get clean fresh fluid faster if you do suck the bulk of the old from the res and fill with new.
"... the bulk ..." is the key phrase here. Never let your master cylinder run dry unless you're prepared to bleed it by itself. Leave a little fluid in the reservoir, covering the valves, and keep topping it off if your tool doesn't do that by design.
Scottydoggs
NJ
like everyone else said, you can leave a bit in there. while your doing the calipers and lines make sure the master is full and dont drain out on ya. it will slow drain on you.
Livebai8
Livebai8
Houston, Texas
Ok cool..
That's what I was thinkimg...i just needed some reassurance on that portion. Thanks fellas!!
X-ray Nerd
