rockola1971
You guys are doing it wrong. Tech 2 scanner...One man bleeding and let the ABS pump do the work for you using the brake bleed function in the tech 2! Its fast and works great.
Right? Lol!!It's only a short trip to Oregon from Houston. Hope you have tire chains for the passes.
the guy working the bleeder valve is the boss... hes yelling, PUMP. HOLD EM. PUMP, HOLD EM. TILL HE GETS FLUID ONLY LOL
Hey guys, I'm going to replace my rear brake calipers. My left rear is grabbing bad. I'm also replacing the rubber brake lines on both sides. When bleeding the brakes I assume you go about it one side at a time? Or do you bleed them at the same time?
Sent from my SM-N920T using Tapatalk
Thanks. I appreciate it.Hey Livebai8, take a look at my post below. I think it will help with a couple of basics and make your task quite a bit easier.
https://www.tahoeyukonforum.com/thr...ushing-brake-fluid.114414/page-3#post-1377032
Do you empty the reservoir completely or leave just a bit and fill with new and refill as needed until all bled?i use a turkey baster to suck out the old fluid, then fill it up with new fluid.
never used that type of bleeder, but they will will do the job as well.
should I empty the fluid reservoir and fill will with new fluid before bleeding?
Your will get clean fresh fluid faster if you do suck the bulk of the old from the res and fill with new.
What's the reason for dot 4?If you're doing a full flush then you might want to consider using DOT 4 fluid. If you're at DOT 3 now.
DOT 4 has a higher boiling point than DOT 3 so it’s more heat resistant.What's the reason for dot 4?
