Did you find a lot of filthy assed grime under the mounts?
Of course I did! Dirt, leaf/plant fragments, a beetle or two...
Can you post pics of the front mount areas?
I could, but I won't. It's an area I don't particularly care to draw attention to, what with it's odd downward curve and all. Looks like the roof was smashed in a little. :p
This is how I did my old Tahoe, where the duals are tucked up and hidden. View attachment 236634
Hidden pipes FTW.
I've always liked dual pipes out the back when done better than just the common way with boring tips. On mine, after deciding that I don't like being able to see the pipe behind the tip even after lowering it, I think I'd like it exiting under and hidden.
Went through the car wash and got his shit going on now. :mad::mad:
Could just be the gasket around the mirror. If you don't find anything obvious, you're gonna have to dry it, pop off that sail panel and have someone spray it with a garden hose. Start low, all around the mirror then move upward.
Used it to drag my little trailer to Walmart to get some tires put on Jenn's wheels. First time I got it above 80MPH since the drop and wheels. I don't know if it's the warmer weather or the 22s are that much heavier, but it feels like it has some extra weight on it now. The 22s ride rougher, as I expected from the shorter sidewall and since they're BRICKstone Duelers. But, at least they're balanced nicely.
Brian12019
