Engine Hours Reset
You mean on a steering wheel? On my PPV I don’t have this buttons on a right side, just cruise control buttons on a left side.
I tried on a speedometer, no luck
Unless you change the steering wheel to one with the other buttons then the only other way is with a scanner, you could pull up to the service department at your local dealer and ask them if they would do it with there scanner, if they are a decent dealer or if you visit there often enough to be on good terms they should do it at no cost. my local dealer would do it for me but I have been going there for like 25 years.
Tim10
Tim10
i dont get resetting it. its good info to have.
unless you put in a new motor.
there have been mentions of battery issues causing it to reset.
try undoing battery for a while
there is also a GM bulletin about it resetting on its own. the fix for that is get a new cluster.
Just called for fun a guy who fixes clusters and he told me it’s pain in a butt , it’s like roll down milage,
Need to reprogram cluster and ecu and he wants $500 [emoji53]
gat0r
DFW
that sucks
& most w/ PPVs will have high engine hours... as most of their life is idling or cruising around.
well he probably has the tool to do it already, I spent $400 to get one working for my 2018 that would clear it, I just tried on mine it doesn't clear the engine hours with the button I know I can do it with my scanner though, he's just trying to make a profit but seems rather high to me.
Tim10
Tim10
that's what I thought, too high, what kind of scanner you have?
BG1988
Ummm, if I were to buy a vehicle, I would look at the engine hours and the miles on the clock. I would be very suspicious if the miles/hour shows an average of 80miles/hr.
leaving the battery disconnected for a while might reset it
Tim10
Tim10
same tool the dealer use's only it's a Chinese hack job, lol, windows 10 tablet with gds2 and a mdi2 clone.
can you check for me please whenever you will have time if your scanner can clear the engine hours/Has this option? If so I'm gonna buy same one
ya, I will check tomorrow I need to re-calibrate the drivers window anyway it seems to have a mind of it's own
Pepper1700
