04 Denali Headlight Inspection and cleaning
Sdp1234
Southeastern PA
My low beams are very dim. Today was the day to take them apart, clean them, and install new bulbs.
A couple pictures of the assembly’s
I’m worried about the flaking mirror material looking down inside the light
If the chrome is flaking off the inside of your projectors, your lights won’t work well at all.
S
Sdp1234
Southeastern PA
Can projectors be purchased separately or do I need to purchase the complete assembly?
You’ll need to buy the whole assembly. Might be able to find some used ones in a wrecking yard or EBay that have real bad lenses that are all yellowed out and steal projectors from them.
Multnomah Falls
Military
I have an 02 and was interested in this and I looked and found only complete assembly listed at RA and GM Parts
I wouldn’t suggest painting the reflector part of any headlight, projector or regular reflector. In projectors especially the quality of the reflector bowl is directly related to the quality of the output. You want something as close to a mirror as possible with the least flaws. There’s no paint that will do that.
Noted.
05Single
afraid of the dark
Buy CB&D brackets for a retrofit. $55
Then get H1 bowls from theretrofitsource.com
Acme super mini H1 - $50
Morimoto mini H1 - $150
H1 halogen bulbs - $10 - $30
H1 HID kit - $30 - $150
Not only will you have new bowls with new reflective and non flaking chrome but you’ll have better output than you would even with brand new oem lights
KeyMoSteel
