Escalade side mirrors on a Tahoe LTZ!
cmatt
No , not Escalade mirrors . They are definitely bigger than oem Tahoe/suburban mirrors , but they are an aftermarket design. Cost about 75% less than Escalade mirrors also
They resemble the size mirrors that are on the trucks. I’d say they sit between the OE suv mirrors and the Escalade type from a size perspective.
iras1976
They are actually about the same size as the Escalade mirrors, just that the Escalade mirrors are a bit more boxy. Escalade mirrors closer to a square where these drift to more of a lengthier rectangular shape.
RST Dana
OH
Here is the factory Esky mirror on my Tahoe.
DenaliBQ
has anyone tried to get the side cameras on the escalade mirrors to work ? And anyone with a 15-16 yukon try upgrading there rear back up camera to a 18+ there supposed to be HD wonder if we would get better clarity on ours as they are crappy on the 15-16
Christian80
Anybody who did the mod has a LH Black escalade mirror cover that he does not need? Preferably without all retainers broken ? Or at least one still alive?
RST Dana
OH
I will look tomorrow.
cmatt
I saw where someone had a shop tap into the Esky mirror cameras. They were installed on a Suburban. It might have been on another forum.
I could have missed it, but I don’t think the rear camera part number changed. Of course, with GM, that’s not always a definitive answer.
K2 Kaiju
The Depths
Nice, how much?
Delivered after tax ~ $131 each after 15off75 coupon (they are listed for 135.xx). Hurry, cause that coupon expires today and is not good on every account (didnt work on my main acct); it appears on your main page when you log on. The mirrors are new, black, without puddle or camera. Seller is in dallas, and same one I got my heated wheel from so I got them in 2 days. Ill post after I get em on - waiting on 1 more switch...
Sent from my SM-T580 using Tapatalk
K2 Kaiju
The Depths
And done. Took about 2 hours - 1 1/2 doing one, and half hour on second (did passenger 1st) as always. Actually not very hard as projects go (easier than heated wheel), but I did do a lot of door panel removal on the gmt 900s (this is similar). No clips broken. The difference in visibility is incredible - way more than I expected; you dont need tilt to see your back up along the lawn. The power fold and memory function work since I replaced both switches, but turn signal was not hot. Now I pretty much have every feature I want (mirrors, fogs, heated wheel, rst grill) without the ones I dont (push button start, magnetic ride, sound dead, over chrome). Cost was 262 for mirrors plus about 75 for switches (I had some Amazon credit so I got them there, but they are cheaper elsewhere). Worth it IMO...
Sent from my SM-G975U using Tapatalk
Christian80
And done. Took about 2 hours - 1 1/2 doing one, and half hour on second (did passenger 1st) as always. Actually not very hard as projects go (easier than heated wheel), but I did do a lot of door panel removal on the gmt 900s (this is similar). No clips broken. The difference in visibility is incredible - way more than I expected; you dont need tilt to see your back up along the lawn. The power fold and memory function work since I replaced both switches, but turn signal was not hot. Now I pretty much have the lux features I want (mirrors, fogs, heated wheel) without the push button start which is being blamed for thefts. Cost was 262 for mirrors plus about 75 for switches (I had some Amazon credit so I got them there, but they are cheaper elsewhere). Worth it IMO...
Not bad. I paid $220 shipped for mine but need caps. I went that way because those were the only ones I found without the blind spot indicator. Why is the turn signal not working?
K2 Kaiju
The Depths
Needs to be wired. I have a base LT without signals. Not really something I care about, and I will probably do a black vinyl wrap on them...
Christian80
You did not get the body harness from Matt? Mine is LT also but has memory seats and mirrors. For the price I believe the harness is well worth it, ads turn signal and puddle lamp as well as autodim.
K2 Kaiju
The Depths
I agree. If my new mirrors had puddle lamps, I would get the harness, but they dont. The switches give you memory and fold capability which is what I really wanted, plus the size which may be worth it alone. I didnt have to cycle it 3 times either - they folded on first try after I installed the switches...
cmatt
Nice! They look great. I like how the black caps blend with the side windows/trim.
BTW my harness will also enable the auto dim feature on the driver mirror in addition to turn signals, etc.
BlackYukon
I'm kind of a Retard
Does it matter what year the Escalade mirrors are for? I just ordered a set and one of them is for 15-17 Escalades and the other is for 18-19.. Will I run into any problems or are they essentially the same?
cmatt
It doesn’t. The main 18 pin connector will match up. The difference is the separate camera connector design. It’s square vs the more rounded one on the 15-17.
Staggered 02
Very nice upgrade. Those mirrors look great on your Tahoes. Price is very good as well. I purchased new ones when I color matched my mirrors. They are very pricey.
Well done gents.
varminpoolteam
