Sam Harris
Throttle body cable bracket for a DBC throttle body. I called them on the off chance they offer a lid without one for us DBW guys that I could buy separately, but they said no plans in making one :(
Stay tuned though, it's going to look badass.
I'm in the middle of a nitrous build right now so things are already getting moved. It's really just sensors anyway. It was $998.95 to my door, comes with rails but not injectors.
More of a supporting piece than a power adder. The stock L92 manifold hangs with most aftermarket options on n/a setups. However I opted to go with it over stock for the longer runners, putting on a 102mm tb, and it is molded from the factory with locations for direct port nozzles.
The plenum volume and runners were the main factor, I'm running TSP's 229/244 .629/.615 112 LSA LS3 cam, Cirdle D 3400, and front/rear 4.11s. So it's a perfect fit to match the low end grunt that everything is set up for.
Man, that sounds just like what I need.. [emoji16][emoji106] looking forward to progress updates! Perhaps a thread of your own exploits is in order...
Chert_Detective
Yeah I'll probably start one when it's closer to being finished and I have some better material to post. Grabbing a Norcal 4/6 kit after the engine stuff. I think I'm going to end up with the 20" American Racing Patrol series which they don't make in 6x5.5, so I'll have a nice write up on redrilling axles and hubs too.
Good stuff going on :waytogo:
CHOO CHOO
BackPagePhil
Manheim, Pa
Are you comparing Phil to a teenage girl? :hmm:
No! Phil seemed a little unsure of himself and I wanted to convey that if my daughter can do it, he can too.
Hahaha my first thought was " oh great, now I gotta make sure I get it done otherwise a teenager will have done better than me"
Then, I thought "this M'fer"......[emoji23][emoji23][emoji23]
Not just a teenager, but a teenage girl lol!! But reading James's posts, I knew he disn't mean it negatively. He was just trying to let you know it isn't a bad job. Did you start it yet?
CHOO CHOO
BackPagePhil
Manheim, Pa
Yep, just got the lower hose off and draining now. Eff that clamp! That was the biggest pita to get to. Took the passenger side headlight off to make it a little easier. I'd say the wheel well trim/cover should come off too if you want it easy to access.
Not sure how long to let it drain, but gonna give it a while.
CHOO CHOO
BackPagePhil
Manheim, Pa
Oook, so everything is done and back together. You're gonna laugh, I know, but I bought the concentrate. Now I know it's a 50/50 mix. Can I pour in the concentrate then fill the jug with water and add that, or do I actually have to premix it first. I don't have an empty jug is my problem
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
As long as both jugs just fit it will mix up.
CHOO CHOO
BackPagePhil
Manheim, Pa
Everything is back together, filled up and no leaks so far. Will check again the next few days just to make sure the fittings are secure.
Cleaned the asphalt with a degreaser and put everything away.
I'd say it took me around an hour, and that was because I took extra stuff off I didn't need to (The front trim pieces on top) and going back and forth with watching a YouTube video.
After everything was back together, I did hear a different noise, took a video to see if it's just normal engine knock or something else. Let me know what you think.
HiHoeSilver
Away!
Chicago
Sounds like pretty normal Chevy ticking to me. What kind of oil is in there?
lol, that lo
sounds good to me, sounds just like mine
All I'm hearing are the injectors ticking.
Sam Harris
Check the oil!
I was gonna mess with you and say it’s the common “radiator tick” but I don’t wanna have you freak out lol. It sounds normal to me.
Mickey_7106
Bay Area
My local Costco. Probably the cheapest I've ever bought it
who here has the turn signal switchbacks installed on there Yukon in the front?, I know someone does I thought it was warren.
veteran111
