They’re not really useful for normal suspension travel, they’re mostly for if you’re bagged and have a lot of up and down movement. Otherwise if you’re static you’re only going up and down a couple inches and thus not moving much side to side during that travel so you just set the left/right at your normal ride height. Even lowered 4” in the rear mine isn’t much off. Also I’ve never seen one used with a girdle, I don’t think there’s room.Does anybody do a Wattslink to replace the panhard bar? That way it doesn’t move at all laterally thru the suspension cycle?
