Got it started....
Ahhhh, the fresh smell of no cats and pure exhaust fumes.......
:bleh::bleh::bleh:
CHOO CHOO
BackPagePhil
Manheim, Pa
Well, you must be right. Let it run for about 10-15 minutes and shut it off. Went back out to start it again and it's dead. Guess I'm buying another battery today......fml.
you don't have a charger? might take a while to charge if it was ded dead
R3cord303
Posse In Effect
Oregon Valley
So out of curiosity, how does this battery drain in 11 days, yet batteries sit on the shelf for months and will start right up. Is there really that much of a trickle running in the vehicle? I guess the alarm, but I wouldn't think that would be enough to drain it that quick
Paracitic draw of some flavor. CAN bus, alarm, phone charger left plugged in, could be anything.
On my S10- i had to go to the mechanic three different times before he found all of them. The last time I actually found out the biggest draw was the ‘you left your key in the ignition’ switch inside the ignition cylinder was super worn out and at random times throughout the night it would just start going ‘DING DING DING DING’ for hours on end- and I only found out after i got home one afternoon, and had the door open, key in hand, headlights off, and it was still chiming. If your battery is in good shape- you have draws somewhere.
CHOO CHOO
BackPagePhil
Manheim, Pa
I'll take it to AutoZone or advance and see what they say.
I'll look into charger/jumpers to keep on hand either way.
I made sure I unplugged everything besides the stock radio so I should be ok in that retrospect.
Alright, do you have a charger you would recommend I get?
anything really I like the old school shumacher's, I bet if you poked around on offer up you could pick one up pretty reasonable, I wouldn't worry about there being any new issue's cropped up, it's just that time of year and it sat for several days the alarm alone could kill it if it was already weak.
CHOO CHOO
BackPagePhil
Manheim, Pa
The wife and I were talking about it and we think the last time the battery was replaced was in late 2015 early 2016 so it makes sense for it being on its last leg.
mikeyss
Longmont, Colorado.
I have dual batteries in both of mine. They are interstate batteries and I wires them in parallel. I drive my 6.2 more than my 6.0, but they both fire up very quickly, even after sitting for over a week. It's just good insurance having dual batteries.
St. Louis
@CHOO CHOO do you have anything plugged into the OBD port, like a Bluetooth scan tool adapter?
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
CHOO CHOO
BackPagePhil
Manheim, Pa
Dual battery conversion? Mine is getting pretty old and I’m thinking about getting two AGMs
2001 Yukon SLT
As much as I'd like to, I don't think I will. Not sure why you would need two batteries unless you have other accessories or just want reassurance. Then that means I have two to replace every 4-5 years.
Obd port is empty unless I plug the autocal into it.
One good battery is all a guy needs unless you’re running a lot of bass imo. You should just get yours checked out like others have said, and 10-15 minutes of idling isn’t going to charge it for shit.
wwiizz
