05Single's virgin build thread. 03 tahoe
eand28
Pennsylvania
Pull flasher out from under dash and clip pin 7
05Single
05Single
afraid of the dark
Which is......?
They should be labeled on the backside of the flasher
And I never knew about this trick. Thanks for the tip. I already have resistors wired up so I’m good for now
Sam Harris
My original flasher:
guess that’s not gonna work for me.
Sam Harris
Yours a 00-02 or 03-06?
03. I may have the same IC on board though... not sure if they’re the same or not. My eyes are too old now to read that shit without a magnifying glass. [emoji1787]
Sam Harris
Would be cool to just clip that and function as normal otherwise. I lost my 3rd brake led as well, after replacing the taillights with different LED’s and can’t see why. I installed LEDs in everything, and all worked, then changed the taillights to different LEDs and the CHMSL decided to quit. (Yes, the fuse is good, and yes the led itself tests ok)
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
damn it, i bought my novita flasher for my 01 from autozone. could have saved $12 with this tiny mod.
Sam Harris
Doesn’t work with 00-02’s. Only 03-07’s
Ok. So the “ear clip” of connection #7 must be for the 00-02’s.? I suspect the same would work on the 03-06, if you get the correct leg..
eand28
Pennsylvania
Guess it works on both. Had a brain fart and forgot which one was which. Meant to post the 03-07 flasher pic
brice715
