New check engine light pending codes..
BG1988
two P0430 codes bank 1 and bnak 2 currently
BAP sensor seems to be outputting bad garbage data this time
barometric sensor = 105kpa ( basically reporting i'm 200 feet below sealevel)
when it should be 80-83 KPa 2300 feet above sealevel at my location
just waiting on that P2229 P2229 code or P0069
anyone know the part number for this?
Do you mean P0420 and P0430? Any blockages around air intake, shopping bag, bug, etc.?
B
BG1988
there was some hesitation this morning on a cold start and was stumbling..
just 2x p0430
but the barometric showing i'm under the sea (or death valley) 105KPA
I should expect to see 91.5 kPa ( with in 0.3KPa accuracy )as seen on my cellphone so it's off by 14KPa
cat temperatures are fine and whats expected 450-550 Celsius
B
BG1988
took it for a short drive you guessed it P0420 and p0430
one set pending and 2nd set stored code
B
BG1988
yep fried them because leaking fuel?
the intake MAF smelled of gas fumes
Short trim is 0.0 idle
long term is 8.6 idle
it changes around
short term is about 5-8 while driving
but the long term is 12.6 is the highest reading while driving
the Map sensor was reporting 91-KPa(which is correct) with Acc on
Barometer was 101-- KPa reading
upon the last start up
i'm just going to fix it and then get rid of it... and buy a Toyota 4runner...
do these look like the factory welds?
it changes around
View attachment 231653 View attachment 231654
Good idea and yep.
montanaboy65
