John03Z71
- Joined
- Mar 27, 2014
- Posts
- 43
- Reaction score
- 14
Can anyone help me understand the following from an Actron Elite AutoScanner (Advance Auto tool)? I tried Googling, searching the forum, and searching the user manual for the tool itself but still have some questions.
HISTORY
"MIL NOT REQUESTED" (does this mean the specific error has been detected, but it will not cause the check engine light to turn on?)
"Since last key cycle NOT RUN" ?
"Since DTCs erased PASS/FAIL"
The above is for P0463 - fuel level sensor.
I'm trying to get my light to go off as I need to get state inspection passed. I've fixed 2 of the 3 'CONFIRMED' codes (P0300 & P1516), the last one being P0133. Currently my check engine is on about 90% of the time, it will randomly turn off then come back on. I can swap out a new O2 sensor no biggie, but my main concern is if the fuel level sensor issue would be causing the check engine light. I just replaced the fuel pump about 4 years ago and do not want to go through dropping the fuel tank again. Thanks in advance!
EDIT: adding more detail to P0133 code: "Oxygen Sensor Circuit Slow Response Bank 1 Sensor 1" -- recommend to replace the sensor or would this be the result of a separate issue?
HISTORY
