kbuskill
Looks good... not dark enough for my liking BUT... its your boat... so as long as you are happy.
it still exist's in limited locations, nearest one to me is about 40 minutes drive and online of courseMade a 555 timer?
I miss Radio Shack.
Factory tint maybe? I’m a glazier so it bugs me when somebody calls glass that’s obvious got tint to it as clear. It’s green as hell if you hold a piece of paper behind it. But go ahead, call it clear lol. The same tint is used in 1/4” flat lami glass. There’s normal tint which is the green, bronze and grey available as stock tints. Then there’s clear which looks way different than the stock green tint. I used to cut patterns for the old cars when they used flat laminated for the doors and vents. Yes Im old lol.I understand it's not "clear"... perhaps I should start referring to them as "factory glass" or "without aftermarket tint".... but most likely I will continue to call it clear... lol
Gotta be able to see at night. Not sure how people drive around with windsields tintedLooks good... not dark enough for my liking BUT... its your boat... so as long as you are happy.
No shit. Can’t get those things anywhere else!
Nice. Didn’t know they carried electronic components. I don’t have any near me anyway though.I use Fry's now.
I think 70% would be fine- I could hardly tell with the stock front glass on the doors- but any darker than that- nuuuupeThat's why I went with a 70% film on the windshield... you would never even know it was on there if I didn't tell you.
I agree... lots of guys on here running 50% and some even running 35% or more on the entire windshield.... I wouldn't want to drive their trucks at night... that is for sure.
I did the 20% on the front side windows for a little more privacy and because it is hot as hades in Florida.
turning right!
turning right!
turning right!
Fog lamps on!
It’s not actually clear, it has a green tint to it but even clear glass is more like 90%. It never lets 100% light through. There is some ultra clear flat glass like Starphire which is higher when it has no coatings but it’s not used for automotive.
turning right!
Fog lamps on!
22.5 PSI oil pressure at 600 RPM! 27/32 from "F"!
Drove the Denali from Naples to Mich. My brother was with me. Left at 5am thurs. and made it to Cincinnatti at 845 pm. Then Friday the rest of the state with ORANGE BARRELS otherwise known as Ohio. Averaged 17.5 mpg. Burned mostly premium with a tank of 89 octane thrown in. Really no difference in performance. Drove mostly 80 except for Ohio where State Troopers were like flies so that was at 74 mph or slower in the many construction zones. The Denali will pull 19-20 mpg at 74 mph.
I've also heard that the factory rear bronze/grey tinted glass doesn't block UV rays. It is only "privacy" glass.^ this. 'clear' glass has an elevated PPM of iron, giving it a greenish tint that is not always obvious when looking through auto glass. if you get to 3/8+ thick glass it becomes more evident. 'white' glass has ultra low PPM iron and appears nearly perfectly clear to the eye. the raw materials have to be sourced from special quarries. the rear tinted windows on most GM SUVs and trucks is actually bronze, not grey or black as it appears and had a transmittance between 17 and 20% as some have mentioned. if i remember correctly, it was generated with varying PPMs of selenium and cobalt.
source: i used to be an engineer for one of the companies that makes glass for a bunch of the vehicles on the road. always makes me laugh when i look through a windshield that has bad ream. how TF did that make it through QA/QC?....![]()
