Replaced the MAF, MAP, Knock Sensor x2, removed tune and placed stock airbox back on to try and diagnose this madness my Yukon decided to do. When accelerating from a stop or under a load, falls flat on its face, bogs down and can here it popping through the intake. Idles absolutely fine, just only under acceleration. Only codes on my GM Tech 2 scanner is P0328 for a Knock Sensor Circuit High Voltage Bank 1. Replaced both knock sensors, cleared code and comes right back up.
I am lost on what it could be, my dad thinks I got a bad batch of fuel. I went through 1/4 tank with no problems then just hit out of no where.
have you taken any fuel pressure readings?
avalonandl
Troy, MICH & Naples, FL
Air compressor from yesterday....
St. Louis
Damn, did the previous owner keep the damn thing parked in a lake?
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
avalonandl
Clearly this thing lived on a dirt road for most of its life. It was the one thing that ALMOST kept me from buying it. But the vehicle was very clean otherwise. As earlier in this thread I looked like Buckwheat from lil rascals when I was done....
avalonandl
the tech2 will do all kinds of stuff, you can get all the part numbers of the modules that are hard to get to, you can test all the channels on your bose amp, lots of fun stuff, lol
I just opened my box for the tech2 and cannot believe the number of cables connectors etc.....
OMG this is confusing. Also my laptop does NOT have a built in cd drive.
1. Is the Tech2 preloaded? seems to be
2. Just connect it to OBD port and turn to run?
3. Don't want to blow my ECM
As an aside its Bosch software (Chinese Copy i'm sure not authorized)
Turned it on when plugged into the wall. Menu works.
Clogged cats is my guess. Mine did pretty much that when it happened to me. I was getting codes for random misfires, MAF codes, etc and it would drive fine as long as I barely pushed on the throttle but as soon as I tried to push it a little bit it would cough and buck and go into reduced power mode. Seems if it can’t get the air/exhaust out through the tailpipe it messes with what the computer sees coming in. I never had an O2 code.
It’s always Bosch software. You don’t need a laptop to use the The Tech2. Install the memory module in the PCMCIA slot if it isn’t already and you’re good to go.
Edit: you only need one of the connectors (the obd2 one) and one cable unless your truck needs the CANDI module, then you need that too. I just leave mine plugged in even though I don’t need it. It makes the cable long so the Tech2 reaches all the way from one end to the other.
St. Louis
Don't forget to use the CANdi module plugged inline between the Tech2 and obd port.
Speaking of that CANdi module, damn that thing is cumbersome. You'd think that they could make it a bit more shapely instead of a big flat square.
2001 Yukon SLT
software is not required unless you want to program something in which case you can copy the files on the cd/dvd to a thumb drive and install from the thumb drive, also the tisweb stuff will run on java as a virtual machine so you really don't even need the old software
Phlipnstik
