What the heck is this?!?
cardude2000
Looks like bubbling on the ‘chrome’ strip. Is this even real chrome? Could it actually be rust underneath??
humer101
NJ,USA
How old is your car? And where are you located?
State?
Sent from my Pixel 2 XL using Tapatalk
drakon543
it looks like an improperly prepped section when it was coated. even when real chrome plating it has to be prepped correctly. looks more like water in paint or on the surface
C
cardude2000
State?
3.5 years, northeast. It could certainly be rust, frankly I thought it was just a plastic was with a Chrome like finish put on it.
humer101
NJ,USA
Very suspect chrome, i never see like that my neighbor told me it might was wrong mixing or they use different glue to attach the chrome.
CMoore711
Sorry if I missed it, but what “chrome strip” are we looking at here? The side door molding?
CMoore711
The side molding pieces are plastic, not metal. So that is for sure not rust.
However, something has happened to it. I’ve seen similar things happen to “chrome” plastic pieces if the pressure washer wand at the car wash is held too close to the “chrome” plastic surface. It’s usually in the form of a line or larger noticeable defect though whereas yours are small specs which is throwing me off.
C
cardude2000
Yeah these are actual bubbles (hard though) and not pitted as they appear...
CMoore711
Well the good news is they’re as easy to remove as a decal badge that’s stuck on with tape.
Replacements come with double-sided 3M pre-installed, and from a quick glance on eBay OEM replacements can be had for about $75/ea. give or take.
C
cardude2000
Good to know. Will have to order one. Thanks
Brace
