Its here.. Finally... WAMS Spec BCM Programming!
GTPprix
Senior Member
Metro Detroit, MI
If you’ve emailed us about custom BCM work in the past it was likely, that at the time we just simply couldn’t take it. These units take an immense amount of time to build just a single unit for one vehicle and in the case of the truck platforms there could literally be thousands of build combinations we would have to account AND the big one… TEST FOR. Even with our recent efficiency upgrades custom units still require a ton of dedicated time.
A few years ago we started compiling a list of the most common modifications we were getting requests for and we noticed a pattern; a lot of people were asking for variations of the same thing. On top of that most customers seemed to be OK when asked if other certain features were included as well for a lower price point would they mind? The resounding answer was no they wouldn’t mind and when can we order it?
It’s taken a few years to get there; but we are finally here now.
Announcing our new WAMS Spec BCM programming!
WAMS Spec BCM’s include our most requested modifications in one convenient easy to order package at a lower price point; all with our new proprietary plug and play method that ELIMIATES the required trip to a dealer (or a high end scan tool) for a brake pedal position relearn after reinstallation!
We think every K2 owner will really enjoy this but those of you with lighter content trucks are really going to love this, here are the included features for this item:
· Remote Start Enabled (Customer will still need a remote start key fob to utilize it)
· Remote Start Cycle time extended to 20 minutes per cycle
· Factory Alarm/Theft Deterrent Added to base model trucks
· Factory Heated seat support added for trucks that don’t have it (wiring required obviously)
· Turn signal “Hyper Flash” Deleted
· Turn Signal Bulb Outage Detection Deleted
· Fog lamps remain on with High Beam
· Fog lamps no longer disable Intellibeam
· Fog lamps remain on with Intellibeam/Auto High Beam enabled (if equipped)
· Tap to pass (turn signal activation) bumped up from 3 to 4 flashes
· Windows down from key fob added (For 2014-2015)
· Windows down from key fob changed to Driver and Passenger front Windows only
· Window down from key fob changed to allow “Vent” setting (release key fob to stop window motion prior to complete lowering)
· Driver (and passenger on utilities) window UP from key fob (hold lock to raise). Express up windows are required to make this work and currently the K2 Pickups only have one on the driver’s side.
· Trucks with a 98MPH speed limiter the limiter is raised slightly to allow a stock truck (a Denali for example) to run a full quarter mile without hitting the speed limiter before the end of the quarter.
Here you can see our final beta test on a complete base 2016 LS I apologize for the vertical video was just really happy to finally get done with the last combination for testing!
Please also check out Phil Gamboa’s (pgamboa) phenomenally detailed review here:
So in closing all of you who have been asking when it would be ready… It’s here LOL
Also BIG Thank you to everyone who participated in early alpha and beta testing this with us. In addition to purchasing several vehicles for this (the latest our 2018 Denali) we tested this on over 20 trucks/SUV’s of different build combinations before we were comfortable enough to start offering this to the public.
greenhornet
Ontario,Canada
What is involved to do this . Is it a program download or a computer reprogram by you? How long and any other pertinent information.Price is nice.Thanks.
TechSupport
I would want windows up from the remote, Maybe longer remote start time but one thing I've always wanted was the rear fog lights like on the Euro models. The wiring is there, the switch and lights are available to buy it's just my dealership told me it needs to be turned on in the BCM. Is that true?
Fifty
Is there a website? Any chance you can modify a bcm for a Chevy Colorado, 2018?
G
GTPprix
Senior Member
Metro Detroit, MI
Yes we can do that as a custom application.
Is it available for an '09 Yukon Xl?
We have BCM options for that but nothing like this for a 2009.
whiteautoandmedia.com and yes we can.
cardude2000
The only new/interesting thing for me would be the fog lights but I would like that.
What’s the process for doing this? Thanks
cardude2000
Wait, another question....would it be possible to add ‘turn off acc’ function so that we can use just cruise control? Apparently the functionality is there but locked out for some of us...
Thanks.
Andy Schmidt
would there be any way to allow remote start with another key fob still in the vehicle? That is the #1 feature that annoys the crap out of me. If my wife leaves her purse in the car, I can not remote start it.
WingsAA
CMFIC
Dallas, TX
I had the HMI unlocked and BCM spec programming done on my 2016 Yukon XL Denali. I can't say enough about the support through this process. Chris answered all my questions (and I had a fair amount) without hesitation and no delay. They performed the work and had a quick tun around on both modules. Everything worked as expected and couldn't have been easier. I now have the unlocked HMI... mainly for the video in motion function for watching the fire tv, etc. The BCM spec programming is pretty cool as well. mainly for me was having a legit capability to have the fogs on with highs as well as the intellibeam still being functional. It's nice to be able to vent the windows as well with the key fob. Overall... I couldn't be happier. Top notch service and communication from start to finish. Now I just need to figure out getting the wire powered so I can turn on the backup camera while in motion.
If it's something you're on the fence about... do it! I know Pgamboa did an in depth review however, feel free to ping me with any questions.
number9
Did you ever get the rear camera while in motion figured out?
Was searching for that. I’d love to be able to display the rear camera while driving. Would come in super handy while hauling dirt bikes on a utility trailer.
WingsAA
CMFIC
Dallas, TX
Yes. I had to make a custom harness. The Yukon's have a slightly different wiring setup. I bought another harness for the rear hatch off ebay to sacrifice as well as another camera just in case I "biffed" up. Hacked it up and soldered and landed the pins so that I now have the camera operational while in motion. Unfortunately, it's pretty much impossible to find the connectors available outside of getting another harness from ebay or the like. Talked with pgamboa at length sharing my info with him as well. Attached are some pics of everything. I can't remember the exact order but have a look and you'll see where I moved/spliced, etc. for making the new harness adapter.... hopefully.
WingsAA
CMFIC
Dallas, TX
pics cont'd...
WingsAA
CMFIC
Dallas, TX
pics cont'd...
WingsAA
CMFIC
Dallas, TX
pics cont'd...
WingsAA
CMFIC
Dallas, TX
pics cont'd...
jkhuntzinger
