Kbuskill's 2008 Burb LTZ "MOD" Thread
That would drive me bonkers, normally they should have some lip edge, as far as I know or have ever had them, personal preference I guess
how do you like the kenwood interface? does it have nav? does it show what street you are on anywhere on the screen when you are not specifically in nav, like listening to the radio?
kbuskill
kbuskill
NE. FL.
Yes it has Garmin navigation which is one of the main reasons I chose this unit. I am a big fan of Garmin as I am used to using them. It also has android auto so you can use Google maps if you choose to.
Yes it shows what street you are approaching at the bottom of the screen when you are in any other screen besides navigation.
kbuskill
kbuskill
NE. FL.
What size is your screen?
The reason I ask is because this Kenwood is a 6.8" screen which, from what the stereo shops tell me, is why it fits the dash kit the way it does.
nice, does it have a "save" feature to save your audio settings if the battery is disconnected, i'm curious I may get a kenwood next time around, I'm waiting for either one to finally start using blu ray not that it really matters but dvd is getting pretty old school for new model aftermarket decks.
kbuskill
kbuskill
NE. FL.
I'm not sure about the "save" feature but I think so because during the course of installing it I unplugged it several times and it would always start back playing the same station as before I unplugged it.
Well I got the Kenwood installed.
I guess the Metra dash kit "fits" the Kenwood and it was partially my misunderstanding the directions. The pics make it look like the stereo has to slide into the dash kit from the front, which it would not do. In reality the radio slides in from the back which leaves it sitting too far back in my opinion, which I why I said it didn't fit because it just looks wrong to me.
I searched a few different places and all the dash kits make the HU recessed which I did not like... so I ended up modifying mine as follows...
Before/unmodified...
You can see how it's set back... I did not like the way it looked.
So I trimmed the back side of the dash kit to make the stereo sit flush with the dash kit.
After/modified...
This is the way it should have fit right out of the box in my opinion.
Anyway, it's all in and working beautifully. Now I just have to get used to the new interface and where all the stuff is in the different menus and what not... mainly the whatnot... lol
That must be a Kenwood thing. Both the Pioneers I just installed didn’t have anything that would keep the HU from sliding back flush, and there were multiple threaded spots for the attaching screws to go into so the kit ends up flush. I’m surprised the Kenwood wasn’t the same. Anyway, glad you got it in. I spent all day installing compressors so we both should get attaboys lol.
Sam Harris
After/modified...
Looks great! Agree that I would prefer it to be either flush, or even slightly protruding.
kbuskill
kbuskill
NE. FL.
not quite sure to be honest I had it with the 8200 I put in the silverado so it's been a couple years I can probably find out though from the stereo shop here.
It's not that important, I was just curious... I'm sure as heck not pulling it all back apart to change it now... lol
NathanJax
Vacation Nathan
Jax, Fl
Looks good. Yeah they all mount from the back, and because it's not a "universal double din", some minor trimming is sometimes used but is fine.
kbuskill
kbuskill
NE. FL.
Got a couple pics for you today so you can see how the navi works.
You can see the name of the cross road you are approaching at the bottom when not on the navigation screen...
And you can see what song is playing at the bottom while in the navigation screen along with what source it is playing from...
kbuskill
kbuskill
NE. FL.
I received my OBD2 splitter today. I hooked it up and got it mounted...
This is after I mounted it in the factory location...
It accomplishes one goal that I had which was to be able to hook the data lines to the OBD2 port without splicing into the trucks harness and without just plugging the stereos connector into the port and seeing the wires hanging out from under the dash.
I tried using the gauges on the HU and OBD2 dongle with my phone and the Torque Pro app and it was EXCRUCIATINGLY SLOW.
It also makes some of the gauges not work on both devices.
If I turn the HU off it works as expected on my phone.
The moral of the story is... the data coming through the canbus lines is just not strong enough to feed both connections at the same time.... oh well, you live and learn, at least I don't have wires hanging out from under my dash and if I need the torque pro app for something I can't do with the HU I will just turn the HU off while I use the app... simple as that.
one thing I like about having a nav is being able to just hit the button at any random jammed up intersection and look for short cuts around it, like intersecting cross streets, comes in handy often.
kbuskill
kbuskill
NE. FL.
Also wanted to mention that my Kenwood didn't come with the little rubber piece that goes into the hole at the back of the dash.
I was going to re-use the one off the Rosen but the bolt was bigger in diameter and wouldn't screw into the Kenwood.
I ended up removing the rubber from the bolt on the Rosen and drilling a hole all the way through it and getting a bolt from the hardware store that fit the back of the Kenwood and mounting it that way...
More than one way to skin a cat as they say.
BadDaddy2003
