Kbuskill's 2008 Burb LTZ "MOD" Thread
I think the center metal brace had to be cut on mine for the w8400nex, the cooling fan was butted right up against it, but I managed to cram all the meastro stuff in there and a siriusxm receiver, the (2) antenna's one for the nav and the other for xm I put up under the front dash piece that comes off, the nav antenna fit perfect right next to the sun sensor, the xm antenna I put over closer to the front of the driver then fished the wires back down the to deck. depending on the usb port on the kenwood you may need another adapter to use the usb port in the console (if yours has that option)
edit: I see yours is a 2008 so no usb in the console, but you could probably add it pretty easily
I added a dual USB port in place of one my power outlets, super easy.
kbuskill
kbuskill
NE. FL.
Thanks for the info.
I added the factory USB port, in place of the passenger side cigar lighter port, to my dash many years ago but you are correct, the Kenwood uses a standard USB plug so I will have to change the cord.
kbuskill
kbuskill
NE. FL.
Well good news and bad news.
The good news is the HU arrived and everything works.
The bad news is the Metra 95-3305 dash kit WILL NOT fit the Kenwood. The Kenwood is to big or the dash kit is to small... however you want to look at it.
So I will get up in the morning and head to a local stereo shop and see if they have a dash kit that will fit.
That makes no sense- double din is double din. The Kenwood and the Metra are both DD. That’s the dash kit I used for my Pioneer DD in my 08 Silverado.
kbuskill
kbuskill
NE. FL.
I agree... but I also found other people online talking about the same issue.
One guy said he ended up buying a GMK318 dash kit and it fit the Kenwood and his Silverado.
Anyway, I am certain that one of the stereo shops can point me in the right direction.
Or perhaps I am just a moron and can't figure out how to get it on, however this isn't my first rodeo with stereo equipment so I doubt that it is an ID-10T error.
The back of the stereo absolutely will not slide into the dash kit, and if I try to put it on from the front it stops and leaves the stereo recessed the thickness of the dash kit... about 3/8" .
kbuskill
kbuskill
NE. FL.
Well I got the Kenwood installed.
I guess the Metra dash kit "fits" the Kenwood and it was partially my misunderstanding the directions. The pics make it look like the stereo has to slide into the dash kit from the front, which it would not do. In reality the radio slides in from the back which leaves it sitting too far back in my opinion, which is why I said it didn't fit because it just looks wrong to me.
I searched a few different places and all the dash kits make the HU recessed which I did not like... so I ended up modifying mine as follows...
Before/unmodified...
You can see how it's set back... I did not like the way it looked.
So I trimmed the back side of the dash kit to make the stereo sit flush with the dash kit.
After/modified...
This is the way it should have fit right out of the box in my opinion.
Anyway, it's all in and working beautifully. Now I just have to get used to the new interface and where all the stuff is in the different menus and what not... mainly the whatnot... lol
I guess the Metra dash kit "fits" the Kenwood and it was partially my misunderstanding the directions. The pics make it look like the stereo has to slide into the dash kit from the front, which it would not do. In reality the radio slides in from the back which leaves it sitting too far back in my opinion, which I why I said it didn't fit because it just looks wrong to me.
After/modified...
Much better.
Ihaveatahoetoo
