Randeez 2012 Budget Yukon Denali Build (stick on hood scoops galore)
randeez
randeez
south florida
S'all good...was a timebomb after last "rebuild". I dont think it was firing for a while. Intake had a pool of oil in it, and there was a lot of water/e85. Would smoke bad when stomping on it. Thought it just need a lot more crank case ventilation but I guess that was some of that oil getting burnt up. Turbo take it like a champ blades all look undamaged
pan blew out into the flex plate, broke one of the heads off the converter bolt so i need to try and get whats left out of it but seems converter/trans is all good.
had to take the pan off, removed windage tray, and take out/loosen the last two main caps to get the crank to spin and remove the converter bolts
seems the gm head bolts stretched a little also - removing with impact the whole way out felt bound up, will be going back to studs next engine.
08grey
That looks violent. What were you doing when it happened?
Sent from my SM-G973U1 using Tapatalk
Laurents10
