CHOO CHOO
BackPagePhil
Manheim, Pa
Have you tried 1a Auto’s 2 wrench trick? You use a larger wrench’s box end to hook the open end of the other wrench so it’s like a cheater bar on a ratchet. Works pretty good.
I actually didn't know about that. Too late now and I'm completely fine with $100 for someone else to do it. I'll definitely keep this in mind though!
the_tool_man
Upstate South Carolina
I changed the oil and installed the fumoto oil drain plug. Definitely gonna make oil changes a little easier.
I had to look up what a Fumoto drain plug was. Found a post from last August on this thread about it. Mine's already on order. Thanks!
What holds the plastic clip on? Just friction?
CHOO CHOO
BackPagePhil
Manheim, Pa
Yeah, I'd be surprised if it stayed on long. Wasn't as snug as I'd like it to be. But, highly doubt something would make the lever move enough to open it. I like the fact I can attach a small hose to it and drain it instead of just letting it pour out into a pan.
Administrator
no idea what style you got, Phil, but from what I'm seeing the valve should have a clip so that the lever can't accidentally be flipped to the open position
Last week I was on vacation, visiting a tool store, and found a 1/2" drive x 36" long breaker bar with a socket for a 3/4" pipe made into the end. With a pipe socket I can make it as long as I want! I bought it immediately for occasions like this. Hammering on a wrench gets old quick. And and impact gun frequently won't fit in the space available.
Gotta post a pic of that puppy.
CHOO CHOO
BackPagePhil
Manheim, Pa
This exact one. F107n. The clip is a little loose. It will stay, but it's definitely not snug.
I bought the Femco, it has a different design. It can’t drain until you screw the fitting on that has a hose already attached pointing straight down from the engine. When you screw the hose on, it pushes the plunger in. It also has a brass cap that screws on to the part that’s in the pan, to keep dust out and just makes it look better when not draining oil.upload_2019-6-11_18-37-41.jpeg
Redoak76
