Steering wheel trim separation-fixes?
So my steering wheel trim decided to start seperating today, I'm looking for fixes that people HAVE done and had good results with that have experienced the same issue. Not really looking for what might work, I can think of plenty of things. Looking for a product that has worked for others thanks ahead of time
PG01
Up here to the right
Nasty, FU....... use super gorilla glue....
Lmao ....;)
Edit: btw my 1978 oldsmobile delta 88 had same shit plastic wooden ring inside the edge of the wheel.... can’t believe gm is still doing that.... i got a new ring and super glued it in...so technically, i did do it... in 1986
Lmao ....;)
Mine cracked into pieces and we used RTV instead, in 1988! LOL
St. Louis
I hate that wood ring! Mine's not seperating or cracked, but when using the heated wheel that wood doesn't heat up like the rest of the wheel and stays cold.
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
I put some epoxy on mine, but I didn't mix it right so it took like month to become fairly fixed it stays on now but would come off again if I pulled on it hard enough, i would recommend some well mixed epoxy then wrap it with some of that blue tape that can be taken off a few days later and not leave a sticky mess, I used zip ties but they weren't very comfortable on the fingers
HACK BLOCK
NYC
sounds like a fix to me
Luggz
