Magnuson Supercharger, Valve Train and other supporting mods. 2007-2013, 5.3L Chevy Tahoe
67RS427
not sure, would say around 10
That's pretty normal... My guess would be too much pressure or a TQ Management setting. I'd need to see the tune file. Contact Black Bear if they did the tune. 6L80 transmissions are a pain to tune and even harder on trucks.
Chrismnj
Chrismnj
NJ
cleaned TB and sent them another log, hopefully they will be able to do something with it
Edit, will try changing fluid as well
67RS427
Make sure your overfill the transmission by an extra QT. They like extra fluid...
Chrismnj
Chrismnj
NJ
ok thank you, is there any advantages of porting and polishing TB on this truck?
Chrismnj
Chrismnj
NJ
Member of another forum claimed that installing TB spacer resolved his issues with hard downshifting, believe it was on trailblazer SS.
67RS427
Any restrictions pre blower will make you more power. Hence why I run a 5" intake and 102mm TB. You could toss on an LS3 TB and it would be plug and play, they are pretty cheap. They are 90mm as opposed to the trucks 87mm. You won't notice a ton of HP, maybe 7-10hp but you will notice throttle response.
*spacer shouldn't have anything to do with transmission downshift
Hodmjstone
