Replacing fog lights
Randy Whistler
Living the dream! I'm just not sure who's dream
In Hell, but I've got a Tahoe!
Anyone have any take-off fog lights from a 2000 Chevrolet Tahoe LS? The lenses on mine are busted out(I know, shocking isn't it? :rolleyes:) and I want to replace them with working units.
I'm open to aftermarket items as long as they fit. I thought about LEDs but decided against them, too complicated for what I want to accomplish. If there are any recommended aftermarket parts that would be a good choice, I'm all ears. . .
Gamzzz
I replaced mine with LED pods and it was very simple and easy to install, I could even use the stock mounting bracket. Just pair the wires to the stock ones and they even work with the stock fog light switch.
TheAutumnWind
I did that on my denali and it worked great, but keep in mind they are no longer "fog lights" at that point and are now "off road lights." The aiming is completely different.
That being said the factory fog lights in stock form are basically candles in an aluminum foil cup. Not very effective...
05Single
afraid of the dark
I have hid projector fog lights.
Randy Whistler
Randy Whistler
Do you have part number/source for the LED replacements? It sounds like they're a fairly simple replacement/install and if so, then I might as well upgrade to LED. Been wanting to upgrade anyway so why not. . . :cool:
TheAutumnWind
I have hid projector fog lights. View attachment 223011
I would 100% go this route next time. Fogs with a cutoff and serious output would be sweet. High output bulbs in the stock fogs just bleed light everywhere. It would be real tough to get a projector to fit in the rectangular housing on the escalade though.
Wish it had the nice round ones like the z71 and denali bumpers.
TheAutumnWind
Probably just generic amazon/ebay lights. Thats how I did my denali
TheAutumnWind
Got them all finished up this weekend!
Off
LED "fogs"
Lows (9011 HIR bulbs)
Lows + LEDs
6 High
6 High again:
Brackets upside down. I can adjust them up/down and left/right and even clock them a couple of degrees.
Much longer wire than necessary. I have it wrapped around a bumper support.
Off:
Heres the pics from my denali
1ssreda4's post that gave me the idea.
https://www.tahoeyukonforum.com/threads/led-fog-light-conversion-for-denali.66892/
Obviously these are round so slightly different than yours but should give you an idea about how its done.
05Single
afraid of the dark
These fit in my rectangular opening. Iirc Escalade and Yukon fogs are he same except different mounting hardware
TheAutumnWind
I custom mounted them to the factory bracket. They fit perfectly in the opening. Just barely wedged and snug in the rectangle opening which keeps them from vibrating and flopping around View attachment 223103
OIC That looks quite good on your truck. I fear that If I tried to do that on my esky front it would look like something was missing. I was thinking more along the lines of a typical retrofit where the projector was installed into the housing behind a lense. I dunno maybe im overthinking it and should just try ordering some cheapo projectors and see how it looks lol.
05Single
afraid of the dark
I was wondering if you meant a retro. Yea mine are pretty hidden and I don’t feel like they’re out of place. A retrofit would be super hard in those housings. Up to you , I like my idea and I think they will look good on your esky. Just $50 to try out
TheAutumnWind
I got the Morimoto (880 bulb /35w / 5500k) HID harness kit. I believe it will be fine in my stock fog housing. I'm waiting for inspiration to install it.
It'll just burn up the stock fog housing and absolutely blind everyone most likely
05Single
afraid of the dark
If the housing gets damaged, I'll have a conversation with Morimoto. They said it would be ok.
...... I don't plan to just drive with them, just want bright light for those moments.
I used a 35w hid kit in my stock housings for almost 3 years. They do get hot and the only damage was the chrome was starting to turn black in some areas. But no melting
CKendrick
