- Joined
- Jan 3, 2011
- Posts
- 50,943
- Reaction score
- 19,372
View attachment 222445 Had it towed because it and my fuel pump decided they didn't want to work together as a team anymore.
I pumped mine out and put the gas in my other rig and my daughters car. Just need to pull the filler nozzle. Then the job is pretty easy.Been there with my previous SUV. It quit right after I filled it up. 26 gallons of gasoline weighs about 180lbs! I ended up letting a shop replace the pump since they only wanted $175 labor to drop the tank and do it.
rs? or ls?
rs? or ls?
ya that's what I use out here in Cali, good road tires wet or dry, doesn't snow here, those should last you a few seasons.LS-2. Stock on these models. The guy I bought the wheels and tires from had them on his Sierra 4WD. I guess he didn't go off-road much at all.
the tires are the shoes and the rims are the socks
Aren't those cladded chrome wheels with the cladding missing? Either way, I love the simple and symetrical look of them.
You know that part you removed was part of the Rim structureThat they are. I've been working on them a little bit at a time for a couple months. Really, the hiccup that stalled the project for about a month was waiting for the center caps to come in from China, devising a cheap but solid way to make them snap in like factory and waiting an additional 2+ weeks for two replacement caps to come in because 2 of the 4 in the original shipment had a different mounting tang arrangement and size.
A six-spoke design just seems to go better with these rigs. These wheels have a much more sporty look, which is the direction I'm going with the Tahoe. They look out of place with the chrome trim. I wanted to swap speakers and install sound deadener when I removed the panels to change out the handles, but I don't have enough time for all of that. I'll probably just change the handles cuz it's really bothering me. Gotta paint those chrome mirror caps and grille, too.
What part did he remove that was part of the wheel structure? In that pic I don't see anything that was removed that was a part of the structural integrity of the wheel, but maybe I'm missing something.You know that part you removed was part of the Rim structure
Just like windshelds are part of the car structure (on modern vehicles )
The part he remove is literally plastic cladding that was adhered to the actual wheel.No, it’s just plastic cladding. Not at all like a urethane-in-place windshield which is indeed part of the structure.You know that part you removed was part of the Rim structure
Phew!! Thought I was going loony there for a bit and completely missed somethingNo, it’s
Nope, you’re loony....Phew!! Thought I was going loony there for a bit and completely missed something![]()
