What should stock ride height be? (So I know how much to lower it)
Grind
My recently acquired '06 Denali no longer has functioning Autoride, as the PO replaced the shocks with regular ones (he disclosed this to me, it wasn't a surprise, but I haven't looked at what brand).
However, it's got a pretty steep rake to it - at least I think it does. Front fender height is 35.25", rear is 38".
Is ~3" difference a normal amount? I want to lower/level this beast.
Thanks, mates.
Grind
Grind
Doh! Pictures help...
cycho
My 2013 stock Tahoe with Autoride and brand new tires measures 38 1/2 rear and 36 1/4 front. This is after sitting for 4 hrs.
Grind
Grind
Thanks. That gives me an idea of where to start. Seems to me, like my front end is sitting low already.
That rear gap looks huge.
It is! It looks even more so in person. I couldn't photograph it well enough.
Big Mama
Virginia
2” drop springs in back would do it. For some reason when both are the same height the rear looks lower.
Grind
Grind
you should fix it
looks the
saggy ford expeditions but you have the issue in the front end
I'm planning on fixing it! ;)
I had a saggy Expedition, but I attributed that to the plow hanging on the front.
I'm thinking 2" spindles and 4" springs should do the trick.
EDIT: Just ordered spindles and springs from TBSSowners.
adriver
You should measure it again when its full. Full of fuel, full of how many people you normally carry, full of any towing weight and measure it again.
Also you should be measuring all four corners. 'Chevy lean', having a 1/2" difference between the two fronts is common.
Grind
Grind
@adriver I measured all four corners, with a full tank and some stuff in the back. I rarely have actual humans in the back. Both front corners were the same, no "Chevy lean", but oddly, the rear had a half inch difference. 38" that I posted was the average between the sides.
Merc1973
Maryland
Its better to measure center hub to fender. That way different tire and wheel sizes wont throw off measurements when comparing.
Drewphil
