Rear wiper and rear defroster not working... any connection?
cfmistry
Hey guys,
So my rear wiper doesn’t work (you can hear the motor clicking but the arm never moves) and my rear defroster isn’t working. Any possible connection to the two?
I’ve checked some fuses, all seem ok.
I checked the wiring to the hatch, no burns/frays.
The defroster tabs are still firm on the glass.
Anything I’m missing before I go replacing the wiper motor??
Thanks,
Cyrus
PG01
Up here to the right
Did you check the fuses well?
either that or the wires inbetween hatch and body have a problem
dnt1010
Tennessee
No way those 2 high power draw pieces would be on the same fuse/circuit. On the rear defrost pull the connectors on the rear defrost tabs and check for power (obviously with button pushed in and lit up lol) On the rear wiper lets pull the cover off the motor shaft and observe the actual motor shaft to see if it is turning and if maybe the wiper arm base has stripped out or bolt has come lose and it is has backed off the tapered splined shaft.....
cfmistry
cfmistry
I greatly appreciate the help fellas. I checked the hatch wiring again and I have no frayed wires. When I turn on the rear wiper, I will intermittently hear some noise from the wiper motor (like it's stuck) but there is no movement at all. Sometimes no noise at all. Broken gear in the motor? I guess the next step is to buy a motor and replace.
Big Mama
Virginia
That means the motor is getting power so you can rule that out. Motor isn’t that expensive and a small PITA to put on. Go ahead and pair the wiper arm and get a new blade while you’re in there.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Does the rear glass hatch open when you push the button on the tailgate? They are interconnected somehow, I always see the wiper motor move when I open the glass.
Big Mama
Virginia
Then you most likely have a short in there. Remove the inside panel and I’m guessing you’ll find the problem. Opening the glass or rear lift gate shouldn’t make the wiper move
89Suburban
SE PA
I'm sorry I didn't mean the wiper arm itself moved, just looks like the wiper motor mount slowly wobbles when you open the glass. I was assuming the motor itself somehow performs both the functions?
Big Mama
Virginia
The wiper is all alone but if it moved at all you’ll want to fix that. The release for the glass is inside the lift gate. It’s not a lot of fun getting that back panel off but I think your going to have to.
89Suburban
SE PA
Now I am getting freaked out. Thanks for the info. o_O
Big Mama
Virginia
No worries there’s plenty of instructions here and YouTube there’s a nut on the outside of the glass you can tighten for the wiper. Just don’t over tighten and you’ll be fine.
cfmistry
cfmistry
Just to close the loop, it was the wiper motor. Replaced it and now I have a working wiper (turns out to be very useful in the rain). I'll get to the defroster next winter probably haha.
Cyrus
89Suburban
SE PA
Here is the wiper arm wobble I am talking about when you open the rear glass with the button::confused::confused:o_Oo_O
Big Mama
Virginia
Yup try pulling the plastic cover back at the base of the wiper and see if the nut is loose. Then look between the inside cover and lift gate to see what’s next
Big Mama
Virginia
Let us know what you find for the next guy. Seems like the mounting bolt will solve most of it.
Durobans
