DOD delete...
erichyukondoit
ok so i have been doing as much research on here as i can, and ive come to the conclusion that its best for my yukon to do the dod delete kit from texas speed. i see that you can get an ls9 cam instead of the 5.3 cam. anybody on here done that and if so how did it work out for you and is there anything else you recommend to go with it?
thanks
Chrismnj
NJ
WHAT ALL WILL YOU BE DOING?
https://www.tahoeyukonforum.com/thr...rting-mods-2007-2013-5-3l-chevy-tahoe.109032/
1. Magnacharger TVS1900
2. BlackBear Tune
3. Airaid 202-270 AIRAID MXP Series Cold Air Dam Intake System
4. Kooks Y-Pipe 28553200
5. Kooks Longtube Headers 28502400, *ceramic coating
* Magnaflow exhaust already installed
6. Moroso 85481 Air/Oil Separator
7. Auto Meter 17118 Triple Pillar Gauge Pad
8. GlowShift Black Gauges
9. Accel 9070C Extreme Ceramic 135 degree boot Plug Wires
10. AC Delco 12673134 Oil Pressure Sensor
11. AC Delco Ignition Coil D513A
12. ACDelco 12617944 GM Original Equipment Exhaust Manifold Gasket
13. Stage 8 8900 Locking Header Bolt Kit for GM Small Block
14. NGK Spark Plugs BP7EFS/3526 - NGK Standard Series Spark Plugs
15. BTR POSITIVE DISPLACEMENT SUPERCHARGED STAGE I CAM FROM CAM MOTION, CM32338206
16. .660" Lift BTR Platinum LS Spring Kit; Titanium Ret., .505" ID .060" Thick Loc., Black Seals, SK001/T/0560/BB
17. BTR Chromoly One Piece Pushrods; 7.400" Long, 5/16" Diameter, .080" Wall, Set of 16, PR7400312-16
18. BTR GM LS ROCKER ARM TRUNNION UPGRADE KIT TK001
19. CAMSHAFT INSTALLATION KIT
20. COMP CAMS TRUNNION TOOL FOR LS ENGINES; CC54702-TL
21. Hummer GM OEM 08-10 H3-Engine Motor Mount Torque Strut 25847739
22. PATC Transmission Pan, GM 6L80 / 6L80E, Deep As-Cast
23. Circle D GM 265mm 2500-2700 Stall 3 Disk lock up Pro Series 6L80 Torque Converter
24. GM Lifter trays non AFM BTR95365-4
25. Delphi LS7 Lifters X12499225-16
26. BTR Head GasketBTR17944
27. BTR LS Head Bolt kit BTR00568
28. BTR LS Multilayer head gasket BTR22033
29. Valley cover 12598832
30. Basic VVT Delete kit VVTBASIC/A80
Chrismnj
NJ
I know some guys just disabled AFM with a tune, though they will chip in. I think is better to do it with a kit,
Thought I responded to this thread already. I wouldn't be putting a car cam in my truck. You'll be moving the powerband up, turning the truck into a dog off the line until you get the motor spinning passed 3000 rpms.
As for the DOD Delete, I was all set to do this. First got the tune and then learned that right before purchase, the entire AFM system had been rebuilt with all the latest and greatest parts. So when my wife heard this she quickly went on a spending spree! LOL
Someday it'll get done and when I do, it will be with a small crane cam of the kind we've talked about on this forum before. Still makes plenty of horsepower and torque without spinning the motor hard or requiring new springs and rockers and a converter to make it driveable.
Chrismnj
NJ
I thought I seen that too.
Kraig
thanks
A tune to match the cam you decide on.
AdrienR
