Matthew Jeschke
I have a horror story
My truck has 230k miles on it original ball joints. They don't have play but 3 of them have ripped up boots. I wanted to replace with moog but got wrong part number on first. So I bought Orielly's house brand. The dust boot looked really chintzy but did the trick.
Next time around I ordered the correct, Moog upper ball joint for front control arm. Then the nightmare begins. First, I ordered the Moog because is a beefier ball joint, and appears to be a better dust boot design. The dust boot is fastened to the joint itself as apposed to the generic design where the boot was a separate part sandwiched between control arm and steering knuckle.
I went to install the Moog joint and broke my breaker bar on the ball joint press. It was hell to try and get it into the control arm. Then I realized Moog makes the joint slightly larger than the hole (unlike the generic one I bought). They put ridges on side of joint to re-seat the new joint in the control arm. I literally had to use a Dremel to open up the control arm seat a bit... Then a 4ft pipe to press the new joint in. At time I thought, well probably this is better although no going back after I've installed this.
It kept going in crooked though because it's a bit larger. I was constantly re-configuring the press to try and push on different sides of the joint so it would install evenly and seat on all sides.
Once it was in I went to install grease zerk only to realize all that fiddling to seat fully deformed the top cap where the zerk goes in. I had to seat the zerk with a hammer and then screw it in. This resulted in a functional but crooked grease zerk. Annoying but not critical.
Now for the moment of truth. The reason I bought the ball joint in the first place. That superior, integrated boot. I started greasing and the retainer clip for the boot failed. It would pop off, release all the grease, and then I'd fiddle forever trying to reassemble it with a small pick. I finally got the boot on and left the ball joint without grease as was impossible to grease the boot without the clip coming off (there's no grease relief on the boot).
I'm in a conundrum. I've noticed Moog has this standard practice of over-sizing their bushings, and ball joints. Now that I've installed their ball joint I cannot go back to another brand as I've resized the opening. And the dust boot design is completely flawed.
I've got a lower ball joint from Moog as well. However, I'm not sure I want to find out what it will be like once installed. Although it appears to have a completely different dust boot design. There's no retainer clip, it has a grease relief, and the boot appears to be much better integrated with the joint.
When I google this issue it appears as though I'm not alone. Folks get really upset at these joints around the time they have to start greasing them.
Any thoughts? Use the lower or throw it away? I literally may have to get a new upper control arm as a result of this mess
