Hide amplifier under console? Where to run power wires?
91RS
GA
I was going to try a body ground to see if that would do anything for the whine but the weather was garbage all weekend so I didn't get to it. I have the gain adjusted to the minimum on the tweeter channel right now and the hiss is still there. The only thing I can think of is that the Dynaudio tweeters in my car are 8 ohm and the Stereo Integrity tweeters I'm using in the truck are 4 ohm so they are getting more power. I think my options are to try using a 4 ohm resistor in line with both tweeters to reduce the power they're getting or to try using a small low power 2-channel amplifier to run the tweeters only but then I've got to find the space to mount that.
91RS
GA
I was going to try a body ground to see if that would do anything for the whine but the weather was garbage all weekend so I didn't get to it. I have the gain adjusted to the minimum on the tweeter channel right now and the hiss is still there. The only thing I can think of is that the Dynaudio tweeters in my car are 8 ohm and the Stereo Integrity tweeters I'm using in the truck are 4 ohm so they are getting more power and maybe I never noticed the hiss when I had this amplifier in my car. I think my options are to try using a 4 ohm resistor in line with both tweeters to reduce the power they're getting or to try using a small low power 2-channel amplifier to run the tweeters only but then I've got to find the space to mount that.
91RS
GA
Austinite
Austin, Tx
Did you ever get this sorted out? I have an 07 Escalade that's sitting in the driveway with the interior torn apart until I figure out how to hook a 5 channel up to the factory Bose without any problems. Has anyone looked into the AX-DSP ? It seems like a decent option.
91RS
GA
Not completely. I installed 4 ohm resistors on the tweeters which reduced the hissing significantly (not even noticeable now) but I still haven't found a new ground for the amplifier. Another thing I found out is that the DSP and amplifier should be using the same ground and they're not. I'm using the stock subwoofer mounting studs for the amplifier mount so I've either got to figure out some other way to mount the amplifier or drill a hole in the body for a new ground which I'm not keen on doing.
I've kinda put it off because it's been rainy, cold, or both around here lately and after our trip in this truck my wife sat in the back for a while and complained she couldn't hear the sound so I bought a mini amp to run the tweeters so I can run rear speakers so I've also got a find a place to mount that! And I'm going to build a new sub box that will go between the second row seats so all the rear area is usable. I've also got to figure out some sort of distribution block for the positive cable so I can also run the DSP and second amplifier off the same power cable. I've just been focusing on tuning my other vehicle and learning REW. Plus, on our trip the amplifier started popping and going into protection mode occasionally which has now gotten worse and it appears there might be a short somewhere in the speakers so I've started disconnecting them one by one to see which one is causing it.
As far as making this work with the factory radio, and DSP will be required. There would be no point in doing all of this if it couldn't be tuned. Before I did the rough tune on this truck it did not sound very good. After I get my crap sorted out I will be installing a system in my father-in-law's 08 Sierra Denali and we're going to use a Dayton DSP which was very reasonably priced. If you're not worried about rear speakers then it's a good option. The factory radio has 5 channels of output because it can play 5.1 surround sound DVD's so at a minimum you have to use the front speaker outputs and subwoofer outputs from the radio. If you want rear speakers you'll need a DSP capable of six channels of input.
Meccanoble
Georgia
I just dont understand the importance of keeping a stock HU. Are all the aftermarket ones that ugly even with the dash kits? The resale value of the car doesnt go up because you kept a stock HU. This isn't a vintage car. Why put all that money and time into such a high end system upgrading everything else but not touching the brains of the operation? Thats like eating right, getting fit in the gym. Healthy body, heart, blood flow but still have mental issues. The mind needs attention too :). This was not going to anyone in this thread, just a general curiosity. Most dont get a DSP. Sound wise, a DSP with stock HU probably sounds better than aftermarket HU with no DSP.
91RS
GA
The aftermarket radios are hideous in my opinion. Maybe not so much in a Tahoe or Yukon but they are disgusting in an Escalade. The available dash kits that you don’t need to cut up the structure behind the radio are terrible looking. The Alpine kit and 8” Alpine radio were the best options as far as looks but they were extremely expensive (like $600 just for the kit and still need the radio) and no longer available. And then adapters are needed to keep the steering wheel controls and chimes etc. It would actually cost me more to use an aftermarket radio because I would have still bought everything I bought and would have still had most of the problems I’m having.
Austinite
Austin, Tx
Ok, so I think I'm getting the AX-DSP (as long as the tech I emailed at Axxess says it will work) and I ordered a pretty sweet 10.4" Tesla style Android screen that works with the stock head unit internals somehow. I ordered it though Aliexpress, so it's gonna be like another week, but I'm pretty excited to see it in person.
Austinite
Austin, Tx
I bought a cheap ass Rockville 5 channel amp that I heard good things about. It that has high level inputs and auto signal sensing so the remote turn-on doesn't have to be connected. It fit perfectly where the old subwoofer was. I grounded it to the front bolt that the subwoofer enclosure was mounted to. Just used a wire wheel and drill to get the paint off and it works perfectly. I ran my power close to where you did. I'm just waiting on the DSP now. I'll post some pics later this evening.
BTW, where did you find a wiring diagram for the Bose amp? It took me forever to find anything close, and I'm still not positive that it's right. And you said you tapped into the wiring after the Bose amp?
Austinite
Austin, Tx
Ok, so after having to completely customize the "Tesla Style" head unit's mounting brackets that I got from AliExpress, I finally got everything else installed. Connecting the 5 channel amp and the Android head unit to the Bose system was kind of a pain in the ass to be honest. And the bass knob that came amp wasn't really built for custom installs, so I did my best. I had to buy a different knob to make it work with my set up and it's a littler bigger than I'd like, but oh well. I'll have more pics in a build thread for the Escalade when I get some time, but here's a few for now.
91RS
GA
That is a very interesting setup. I looked at the install instructions for that thing and interesting how it uses parts of the factory radio.
What did you use for your amplifier ground? I still haven't messed with mine any more. I've got the wood cut finally to build the new sub box and I was still trying to chase down the cutting out but it does it so infrequently that I've gotten no where. I've been disconnecting each speaker from the amplifier one by one so see if the issue lies there and I've got one left. I figure I'll go ahead and install the tweeter amplifier when I get a chance to get back to this and that will help narrow the issue down even more.
Austinite
Austin, Tx
Yeah, it's interesting AF and I still don't quite understand why exactly it keeps part of the factory radio. I had to completely make my own brackets for it to fit too. The seller was of no help and acted like that was totally normal. I've heard that is pretty much how it goes with sellers on these units.
I grounded my amp to the front stud that the old subwoofer was mounted with. Just completely sanded the paint off and it seems to work great.
Austinite
Austin, Tx
I had a whine on my 2000 Tahoe when I did the stereo on it and I tried 2 of those PAC SNI-1 Noise Isolators thinking that might help, but nothing. Then I read somewhere that if you ground the stereo cage sleeve itself to the body that might help. Well sure enough, I just used a couple of the small screw holes on the sides of the cage sleeve and ran 2 different grounds just to be sure. Completely eliminated the whine. I have a small whine on the Escalade when i have the source as radio too, so as soon as I get a chance I'm going to try the same thing.
91RS
GA
Ok, I was going to figure out how I could ground to one of those studs and still use it to mount the amplifier. It looked like you didn’t have the room so that’s why I asked.
Yes, I’ve read a lot about the noise and the big thing I read was ground close to the amplifier and use the same ground for all the components. I was told my whine is likely caused by the DSP power and ground not being the same as the amp. As for the hissing the main recommendation was use a different amplifier. I was just going to deal with it but I found a good deal on the mini 2 channel amplifier so I pulled the trigger. I just haven’t had a chance to install it with my other projects going on.
Austinite
Austin, Tx
Oh sorry, I guess I should have said rear stud! I used those front 2 to mount the amp. I meant the single stud that was just below the cup holders.
91RS
GA
I finally figured out my cutting out issue. It finally did it longer than just a split second two days ago and the second time it did it I was able to pull into a gas station and jump out and start moving stuff around to see what would make it come back on and I found the screws for the fuse under the hood had worked loose! Probably from the dirt roads on our trip (that was when it started). Tightened them up and it seems sorted so far.
Austinite
Austin, Tx
Always nice when it's something easy like that!
Meccanoble
Georgia
This is exactly how mine is setup.
This unit looks sick! It would be great to have a unit that can run 2 sources at once like Navigation on top part where truck shows and a video feed of some sort at bottom. Wish I had the customizable knowledge to do this.
a1parrothead
