qcon
Huntsville, AL
Is that set to fastest in the video? Almost looks like a loose wire or bulb or something. Do they have them to make all 3 (left, right, center) brake lights strobe?
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
That was the fastest setting. This is the middle setting. I agree, the fastest setting looked a bit like flickering rather than strobing.
central222
south dakota
Running e85, love the xtra horses. Sofar no hard starts. -9 in the garage when started, 20 minute run time before I left. Not a fan how fast burns through, but at $1.74 gal. GM's factory remote start, not a fan. 20 minutes, not enough time on days like that.
Sent from my SM-T580 using Tapatalk
BourbonNcigars
Jumped in my Tahoe after work...
Cranked it...
Heard a knocking sound...
Clunking sound underneath on downshifts...
Schizophrenic transmission...
Said to myself, "Purring just like a GM should"....
Finished the drive home with a smile.
It's a newer model one. Once you put it in it automatically pops up. I have never had it flashed to the truck. Not sure I'd it will go away when I do.
Sent from my SM-G960U1 using Tapatalk
ya mine had that till it got flashed then it was gone, but it wasn't 100% compatible with heat in my truck, worked fine in the summer for cool but would only give heat in the back if I had turned all the way to 90, it was looking for a sensor I didn't have
St. Louis
I like that speed much better!
Link to the strobe modual you bought?
2001 Yukon SLT
