Upstream vs Downstream O2 Sensors
Hi-psi
Atlanta, GA
Ok, so, my understanding is that the downstreams are for the most part there to measure the effectiveness of the emissions control components and that the upstreams are primarily the values used for drive-ability, air/fuel management.
Where I'm going with this is as I gradually work through little job after little job on the '08 Denali I picked up back in March, coming up soon I was thinking of replacing the upstream oxygen sensors.
For the most part, it runs/drives fine, no codes. It does have an occasional stumble at idle. I've read a bunch of people saying that's just a tendency of the 6.2, others saying that a working, but lazy oxygen sensor can cause it. I also will sometimes get a little bit of part throttle under heavy load detonation. It isn't a fuel quality issue as I only run 93, and only from top tier brand/stations. Fresh plugs, wires, air filter, new fuel pump, etc, so, to me, it's got to be a fuel delivery issue.
Is it better to just replace all four sensors or would I likely see whatever benefit (if any) that I would get by just replacing the upstreams?
Just interested to hear anyone else's thoughts or similar experiences.
Robert, if you want to keep good tabs on the condition of the cats, make sure those downstream O2 sensors are working good. You can use a good scan tool to graph them in action and determine if they're doing what they're supposed to do within spec. I was all set to replace mine but they are all performing perfectly.
I'd chase that stumble down though if I could.
Big Mama
Virginia
My experience on vehicles the family brings me to fix is chasing the code. I replace The upstream then another code and so on. Follow James’ advice
the_tool_man
Upstate South Carolina
You are correct. Upstreams are used in closed loop to control air/fuel ratio. Downstreams monitor catalyst performance by comparison with upstream output. I just had my downstreams turned off in a tune. It didn't hurt a thing.
My upstreams are due for replacement. Indeed, my tuner monitored them while driving, and found they weren't quite performing to spec. I also have the occasional tremor at idle. So I'm hoping new O2s help. Do keep us posted on what you find with yours.
SnowDrifter
Sasquatch Country
What sort of a stumble at idle? Like a 1 or 2 cylinder misfire every few seconds? I have the same on my 5.3. Graph your O2 sensor data. I've found it trends with then the car's ECU bounces to lean. I suspect it's because the factory injectors have a fairly wide tolerance as far as what's deemed acceptable as I've read that a set of balanced injectors tends to smooth the idle.
Hi-psi
Hi-psi
Atlanta, GA
Precisely. No codes, no misfires. I've watched the individual cylinder misfire counts live and there's nothing. It's just a very random, very light stumble/miss.
This coupled with the random part throttle under load detonation I get from time to time had me also thinking injectors.
Detonation is typically due to too much timing, low quality fuel, or not enough fuel. It will exhibit the random detonation on the stock tune, the Diablo 91, and the Diablo 93, but WOT is fine. I only run 93, and from a top tier brand/station, so what that leaves is not enough fuel. As far as I know it's the original stock injectors, so with 200k+ miles I'm thinking maybe one or two of them has a funky spray pattern or just isn't optimal. On the list eventually is to replace the injectors. Every 3-4 tanks I run a bottle of Techron through it, so any improvement from cleaning them in place is done.
For now, after seeing some mentions here and there about O2 sensors with a lot of age/miles on them not throwing codes, but just being a little "lazy" in their readings, and replacing them resulted in smoother and better running, I though perhaps my next little job would be that.
I have a random light stutter (what may be referred to as a "miss") at idle sometimes.
*In for results of fresh O2 sensors.
hagar
Start by cleaning your Maf with some electronics cleaner, then scan your upstreem 02 sensors and look for a difference between the two in positive or negative fuel trims. If you get an exhaust leak pre 02 sensor for example, one side with be showing more positive fuel trims than the other side. Same if you have a vac leak that is only on one side of the engine.
It doesnt take long for someone qualified watching the data to figure out whats wrong.
hagar
Oops, didnt finish the thought. It will also show if one of the sensors is pooched. If the sensor is shot and reading say -15 fuel trims, it will cause the engine to run lean and can cause pinging
Dmascari1984
Houston, Tx
I have the same “misfire/stumble”. Everyone tells me it’s normal. I can’t stand it. I did check my timing with blue driver and it bounces around while all my other cars are steady. Driving me nuts. Have you found any solution?? FYI here’s my data at 2500rpm no load
gpracer1
Phoenix
Misfire stumble is not normal.
Your graph looks ok, upstream O2 sensors should be constantly swinging (narrowband).
Where/when is the misfire or stumble?
thompsoj22
Ditto on the stumble/tremor at idle. it does seem more pronounced as the engine is warming, not nesessarily initial startup but in between cold and op temp. after a long duration of highway speed and then coming to an idle sometimes it is smooth as glass. ill be watching also.
Are you sure it's detonation and not timing being pulled? Torque Management can and does pull timing randomly even after much of it is removed. A few months back I had my tuner advance the timing while driving, chasing a mile per gallon performance gain, and the timing was being pulled while cruising, the KR meter was going off a lot so we put it back. I went back to E85 so we haven't sorted that one out yet.
I have the same “misfire/stumble”. Everyone tells me it’s normal. I can’t stand it. I did check my timing with blue driver and it bounces around while all my other cars are steady. Driving me nuts. Have you found any solution?? FYI here’s my data at 2500rpm no load View attachment 212961
Your sensors look good as Marc says. Check or change your plugs and wires, double check the gap. Bank 2 Fuel Trims are a bit high to me. Check your intake gaskets with a propane torch while watching the O2 sensor graph.
HiHoeSilver
Away!
Chicago
Trims are negative, no? Under load at 2500. What do they look like at idle? What kind of gas is in it?
Dmascari1984
Houston, Tx
Thanks guys. Did propane and carb cleaner test No vac or exhaust leaks. changed manifold gasket anyway because i heard they fail a lot($50 and 3 hrs not too bad)no change. Had already done plugs and wires. Attempted to do injector pulse test but tester broke(wtf). Went to check fuel pressure and I think I may have found the issue( and possibly a lot of other folks that have the same issue and haven’t been able to solve theirs). I hooked up a fuel pressure test kit and observed the gauge prime properly to 56psi. From what i know, when it is running the gauge should stay pretty steady. Mine was fluctuating very rapidly from like 38-45psi. I know this isn’t scientific but I pressed the purge on the gauge and noticed the fuel was coming out of the line properly and then I would get a stream of bubbles In the line. Then it would go clear(gas only) again. Then more bubbles. In my opinion that would make the gauge fluctuate(air compressing and expanding etc) and cause the lean condition( not enough fuel due to the bubbles being mixed in. Soo I’m thinking it’s a seal somewhere in the lines or the supply line is getting air in it while pumping gas up in the fuel tank. I’ll attach the videos of my gauge findings. I’m a DIYer and have limited knowledge. Just enough to get myself in trouble. Hope this will be the answer. I’m selling the truck soo the wife doesn’t want me to change it but I want to anyway just to see if it’s the problem lol. Btw my fuel trims are crazy. Sometimes negative then sometimes positive. It was in rich when I posted earlier and had been lean for a few days now. Like +9 ltft.
https://share.icloud.com/photos/0p7T_0iHkFElmOMNa1bBVGjgQ#Home
thompsoj22
Anxious to hear from those with knowledge as this sounds possible, but how do you induce air into a system with a submerged suction pump and no return plumbing design.
That looked to me like an inexpensive gauge, one not dampened with oil. The pressure looked normal. If the fuel pressure was really bouncing around that much one would think the idle would have been terrible. I'd like to see what the scan tool sees for FP.
Dmascari1984
Houston, Tx
I was thinking the line inside the tank that pushed the fuel up. Or possibly an irony somewhere.
BadDaddy2003
