Hello, let me introduce myself and my NNBS/GMT900 Tahoe
Fleshe
Hello,
My name is Nathan Parks and I'm an electrician by trade and car enthusiasts at heart. I currently own a 2007 Tahoe and have owned it for about 4 years now. I'm currently in the process of building her up after blowing the transmission for the 2nd time. I would like to start a build thread.
Thank you advance.
Hello,
My name is Nathan Parks and I'm an electrician by trade and car enthusiasts at heart. I currently own a 2007 Tahoe and have owned it for about 4 years now. I'm currently in the process of building her up after blowing the transmission for the 2nd time. I would like to start a build thread, could a mod please point me in the right direction as to what section to post it in?
Thank you advance.
https://www.tahoeyukonforum.com/forums/under-construction.76/
Fleshe
Fleshe
I purchased my Tahoe about 4 years ago for $15,200 with 87K miles and instantly fell in love with the body style and everything about it. I've always been a huge fan of the LS platform so after blowing my 4L60E for the 2nd time I decided to pull the motor and start building her up for more power and hopefully boost this summer. I drive it like I stole so after toasting my second transmission I decided to have the factory 4L60E built up for about 600hp for now and will upgrade to the 4L80E once I'm ready for boost. My build list is below for engine and transmission. I'll update it for suspension, exterior, and interior mods as time becomes available.
Transmission Work
  1. Corvette 2nd Gear Servo - $25
  2. Beast Sunshell - $40
  3. Billet 10 Vane Pump Rotor - $159
  4. Sonnax Boost Valve - $45
  5. Billet 4th Gear Servo - $50
  6. TransGo Performance Separator Plate - $25
  7. Circle-D HP 278MM 3200s Converter - $500
  8. Derale 15800 Electra-Cool Cooler - $155
  9. -6 AN Cooler Feed & Return Adapters - $10
  10. -6 AN Nylon Braided CPE Line Kit - $58
  11. -8 to -6 AN Reducers - $12
  12. Misc -6 AN Fittings - $35
  13. Wiring Relay Kit - $36
  14. Heavy Duty 3-4 Clutch Pack - $60
  15. Royal Purple Max ATF - $90
  16. AEM 30-4402 Temperature Gauge - $177
  17. Anchor 2638 Transmission Mount - $13.88
  18. ACDelco 25789571 ATF Fill Tube - $13.42
Engine Work
  1. BTR Stage 4 Truck Cam - $389
  2. BTR .560" LS6 BH Valve Springs - $69.99
  3. BTR 2001-Up LS Hat Valve Seal - $19.95
  4. BTR Cam Install Kit - $42.99
  5. BTR 3 Bolt Cam Kit - $43.99
  6. BTR LS Chrome Pushrod 7.35” - $94.00
  7. CP Heavy Duty Timing Chain - $48.50
  8. CP 6.2L Valley Cover - $45.00
  9. CP 07+ Lifter Trays - $35.80
  10. CP LS9 MLS Head Gaskets - $119
  11. CP Crank Damper Bolt - $4.99
  12. DELPHI LS7 Lifters - $99
  13. Melling M295 Oil Pump - $50
  14. Dorman 917-303 Dipstick Tube - $14.89
  15. Gates K040378 Multi V-Groove Belt - $14.66
  16. Gates 22437 Lower Radiator Hose - $16.99
  17. MSD 32819 8.5mm Wire Set - $72.57
  18. Engine Pro Bushing Trunnion Kit - $154.98
  19. OMNI K1236 Motor Mounts - $56.10
  20. 234-4317 PRO Cylinder Head Studs - $99.89
  21. Dupli-Color 163807 Ceramic Paint - $51.76
  22. VHT 201007 Wrinkle Black Paint - $41.56
  23. Auto Dynasty Black CAI - $68.88
  24. Lower Gasket Set - $52.65
  25. DNA HDS-CA07-48-53L Headers - $349.97
Faded BG Tahoe.jpg Industrial BG Tahoe.jpg 2018120595140658_01.jpg IMG_20181202_001405.jpg IMG_20181202_194604.jpg
Transmission Work
Engine Work
View attachment 212457 View attachment 212458 View attachment 212459 View attachment 212460 View attachment 212461
Gonna be an interesting build. I like the look of the Hoe. Looks like a PPV.
Bruh...
Mine is Graystone, too, and I'm planning on what looks to be a similar drop as yours. I'm also in the process of de-chroming it. So far I just have it de-badged and the bow ties color-matched. I've gotta know your suspension setup! Amount of drop, what parts, wheel and tire size, any issues, etc. I have some custom fabrication ideas for my suspension once dropped.
Fosscore
Welcome and nice work already. Look forward to more updates.
kbuskill
NE. FL.
Small update, I finally got the motor done and it's going back in this evening.
Sent from my Pixel 3 XL using Tapatalk
Looks great... nice color choice.
What headers are you running there?
Fleshe
Fleshe
So I ran into some big engine issues about 300 miles in. Currently pulling the motor back out to go back through it. :(
I lost oil pressure and the oil looks like shit.
It is, what it is
I've also added two videos of what it sounded like once I got the idle tuned in with HP Tuners. It sounded nice before it all went to shit.
That really sux. Figure out what might've happened? Think that's bearing material on your drain plug?
Fleshe
Fleshe
I lost two Cam bearings. Fortunately, the Cam and Crank are okay.
Worst case scenario according to my machine shop is I'll have to get a new block. Since the cam bearings just fell out, chances are the holes in the block are now too big and won't hold new Cam bearings.
If this is the case, I have a iron block 6.0l that needs a crank and I'll probably just go that route. It already has after market pistons and rods and was originally built for boost with lower compression.
Def could've been worse. Do they have a guess how it could've happened? Non lubrication?
Drewphil
