Tahoe/Yukon Headlight Information Thread
05Single
afraid of the dark
CB&D makes brackets to retrofit hid projectors into them.... (lol no I dont work for them I'm just super pleased with their brackets)
For the tahoe lights ? I know they do for Denali lights.
adriver
Cajun Jamie
SW Louisiana (originally) and DFW area presently
I've read this thread from start to finish. I am leaning toward Depo's to upgrade the OEM. I am still unclear on choice of bulb. I am not wanting to throw a bunch of glare, nor looking to spend $$$ on bulbs that may only last 1-2 years. So for a decent upgrade would a lower end be just replace the lenses with Depos and add a decent halogen bulb, and on the higher end, replace with Depos and install something like Supernova V4's? I'm stuck on which bulb to use.
BeenChevy
Minnesota
That'd get the job done with a silverstar bulb or an LED that doesn't take up as much space - I think a V4 LED would run into the pesky frame assembly when you're trying to re-install the headlight housing ~could be wrong. A ribbon cooled LED might fit ok. Anyone run a low profile LED that clears?
Ran the silverstar ultras knowing while I waited on a set of HID's. The glare you'd expect from HID is focused well by the Depos and hit the targeted patch of road much better than the ultras. Go with a decent set of HID in my opinion. I'd otherwise try an LED that'll fit but halogen are just lame.
Cajun Jamie
Which HID's did you go with?
TP143
What are you guys using in the Yukon’s that could be done like the depo lights?
DenaliAK
Colder than you
Alaska
Soulsea...been awhile since I've been around. Life has a funny way of distracting you from things that don't matter as much...lol.
This is a great write-up. I'm still rockin' the same retro. My Depo lenses need to be polished, but that's about the only complaint.
Xray70
Georgia
Finally found a set of headlights I was comfortable with to replace my factory set. I got a pair of Spyder Projection headlights that have LED accents but uses all factory lights for headlights, DRL, signals and park/marker lights.
Install is wrapping up with no issues.
Lol, looks like a face grinning.
Shovel
Looks great! Please post up when you get it all slapped together and let us know how's the light output.
JamesinAbilene
