donjetman
- Joined
- Oct 22, 2018
- Posts
- 2,011
- Reaction score
- 3,696
Duplicate?
FYI the driver rear is almost impossible to get the Dorman clamp on due to the firewall. Some guys have figured a way but it ain’t easy. The others are a breeze.
The bolt clamp gizmo is a breeze to install on the passenger side. Took me about 15 minutes. I then spent 15 minutes looking at the driver's side and called it a day and went back inside.
You should look at replacing the swaybar bushings and endlinks. Makes a huge difference.
Right, the end link bushings were one of the first things I replaced.You should look at replacing the swaybar bushings and endlinks. Makes a huge difference.
Thanks, I'll order some.I recently bought some Moog bushings for mine. They're blue and much stiffer than the factory rubber ones. I'm guessing they're polyurethane, but I don't believe I read anywhere that it stated they were poly. For mine, it was Moog K200222 ($7.11 for the pair on Amazon) for the front and Moog K6408 ($8.47 for the pair on Amazon) for the rear.
Amazon says they fit. ORDERED, be here FridayJust double-check the part numbers for yours. With it being 4WD/AWD, it may have a different diameter bar(s). They should still be about the same price and I think they're a nice upgrade being a stiffer material.
